Disc Brake Question- Mtbr.com
Results 1 to 5 of 5
    Bored
    Reputation: bigwheelboy_490's Avatar
    Jan 2003
    Disc Brake Question
    Not a 29'er question directly (I'm mounting a disc to the rear of my bike now that I've tracked down a Fisher Frame Adaptor).
    That said, are the calipers on a mechanical brake the same for front and rear, only having the adaptor differ? Or, are there specific calipers for front and rear?
    MTBR is serious stuff.
    You never get better until you get out of your comfort zone.
    Recovering couch patato
    Reputation: Cloxxki's Avatar
    You'll have to specify a brand and model for that question I'm afraid.
    Klok - XC - Skate - Ski
    The Duuude, man...
    Reputation: ncj01's Avatar
    Quote Originally Posted by bigwheelboy_490
    I beleive they are different...ie, you can't bolt a rear caliper on teh front, nor a front on the rear.
    I think you can interchange rotors though.
    FS: Everything
    Reputation: Soupboy's Avatar
    Naturally...
    ...it depends. Are you running different sized front/rear rotors? If so, then maybe yes, the adaptors may indeed be the same size.
    If you are running same size rotors then most likely the adaptors will be different due to the relative mounting positions of the IS mounts fr/rr.
    Sean
    Professional Amateur
    The Avid
    road set I rec'd today seem to be the same,except for the brackets.I compared them and I can see no difference in the angles of the way they mount,or entrance angle of the cable.
    Hope this helps,Dan
    no signature
  1. Silly disc brake question...
    By Pedro2005 in forum Brake Time
    Last Post: 12-19-2004, 01:24 AM
  2. SC Chameleon disc brake question
    By dbsantacruz in forum Riding Passion
    Last Post: 11-04-2004, 12:12 PM
  3. SC Chameleon disc brake question
    By dbsantacruz in forum Brake Time
    Last Post: 11-03-2004, 08:17 PM
  4. Couple of disc brake question ??
    By nickwood in forum Brake Time
    Last Post: 07-01-2004, 11:11 AM
  5. AVID mech disc brake question, on a SS....
    By hu-man in forum Singlespeed
    Last Post: 03-07-2004, 10:48 PM
