Devinci Django 29- Mtbr.com
Results 1 to 20 of 20
    Reputation: Velorangutan's Avatar
    Devinci Django 29
    The replacement for the Devinci Atlas is going to be called the Django 29. I'll post pictures of actual bikes as soon as I receive them.
    Reputation: d365's Avatar
    when are they going to release details, geo charts, etc? 120mm R?
    ***removed the Geometry Chart for now. I'll post it back up once I confirm it's correct.
    Quote Originally Posted by d365 View Post
    It's set up for 120mm rear. Looks like they are pairing it with a 130mm fork.
    Feb 2005
    Pretty low BBs
    Oct 2013
    Looks awesome, have been waiting to hear about Devinci back in 29er territory.
    Looks like a really great update to the Atlas, IMO. Really dig that they went with 120mm in back, and pretty much addressed all my negatives about the Atlas. Though that BBH....
    Might be worth looking at the Marshall 27.5+ which is advertised and being 29er compatible. I don't have one in yet to check how it changes things to convert it, but the Devinci geo chart shows the Marshall as having a higher BB.
    Dec 2009
    I wonder if the reach for the large is correct. There's a huge jump from the medium, but then it's the same as the xl.
    Sent from my SM-G930V using Tapatalk
    Should be 468 based on top tube difference.
    Dec 2009
    I was going to guess 460/464 based on 20 mm increments between sizes.
    You may be right. The progression isn't totally linear between the top tube increase and the reach increase.
    If you look at the top tube measurement, when it goes up by 20mm(581 to 601) from S to M the reach goes up the same amount.424 to 444
    M to L the top tube goes up by 24mm.(601 to 625). The reach would go up 24mm also.(444 to 468)
    L to XL the top tube goes up by 23mm.(625 to 648) The reach goes up only 16mm (468 to 484) following my linear reasoning it should have been 491.
    So until they fix the number a guess would be 21mm M to L at 465. And 19mm L to XL to 484 that way.
    This looks to be because the ht is the same S to M but goes up 10mm between M and L and another 10mm L to XL.
    Devinci seems to have a trend of releasing erroneous geometry charts, which they later correct. I noticed this most recently when they released the Hendrix last year. I sure hope the BB height is an error; if not, I don't know WTF they were thinking when they designed this frame. I've never seen a 52mm BB drop on a 130/120mm FS frame. 36mm drop is the upper limit of usability on a FS trail bike for where I ride.
    The 2017 bikes have been updated on the website:
    DEVINCI
    Dec 2009
    I consider my 2013 Atlas carbon frame to be pretty stout (the front triangle at least- I sometimes detect some flex in the aluminum rear end). I'm perplexed at why the Django carbon frame weighs almost a pound more?
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by TedS123 View Post
    Probably because the Atlas was aimed more at aggressive XC/racing and the Django seems to be orientated at trail?
    Dec 2009
    That makes sense, but the Atlas, at 6 pounds, already seemed more burly and capable than most xc frames (many of which are closer to 5 pounds). The new Intense Primer frame has similar travel and intent, and supposedly is under 6 pounds for the top-level carbon frame only. So I was a bit disappointed to see the Django frame at 6.75 pounds. To me and my riding the added weight has no benefit.
    Squeezing every last ounce out of a carbon layout has to be pretty time consuming, more investment, more of a warranty risk. Maybe they thought sales didn't justify the extra costs, or price point.
    I once had the marketed - lightest Al frame you could buy for a fs xc race bike.... I, and many others, eventually found the weak spot.
    I'll get one on the scale when I get them in.
    I ordered a 7.5x2" stroke shock and a 2mm offset bushing for mine. Should bump the travel to 135mm or more. Stay tuned....
  1. Devinci django?
    By spoker247 in forum Devinci
    Last Post: 11-10-2016, 01:19 PM
  2. Devinci Wooky SL
    By WookySL in forum Devinci
    Last Post: 11-15-2014, 08:32 AM
  3. You know you're a Devinci fan when...
    By pulpwoody in forum Devinci
    Last Post: 01-16-2014, 08:44 AM
  4. Which Devinci ??
    By Licketysplit in forum Arizona
    Last Post: 12-06-2012, 08:34 AM
  5. My god I want a Devinci Remix
    By stefanb in forum Devinci
    Last Post: 07-04-2008, 06:22 PM
