Creaking Carver EBB on Rig...- Mtbr.com
Results 1 to 8 of 8
    hispanic mechanic
    Reputation: sslos's Avatar
    Having some issues with the Carver EBB that I have in my GF Rig. It's creaking, and still slips a bit.
    I've sanded the shell, lubed the wedge nut, made sure it's tight... starts o.k. after I service it, but that doesn't last long.
    Anyone else have any ideas?
    Los
    Support your local trail organization.
    www.swimba.org
    indigosky
    Guest
    call bikeman.com?
    hispanic mechanic
    Quote Originally Posted by indigosky
    call bikeman.com?
    Yeah, I kinda wanted to see if I could find a solution on my own. I purchased the bike 2nd hand with the EBB, and I'd hate to bother them since I didn't buy from them.
    If all else fails, I'll go back to the source, though.
    Los
    www.swimba.org
    poser Administrator
    Reputation: rockcrusher's Avatar
    Aug 2003
    sure it is the EBB and not the BB?
    MTBR Posting Guidelines
    calories>electrons
    hispanic mechanic
    Quote Originally Posted by rockcrusher
    Yup. Fresh BB with anti-seize on the threads, grease aplenty on the spindle splines (ISIS.)
    Well, pretty sure it's not the BB, I should say. I actually thought that I should remove, relube, retorque.
    Thanks for the input though, guys. I always like to have another pair of eyes check things, even if they're iEyes.
    iEye?
    iEye, cap'n!
    Los
    www.swimba.org
    I had an '06 Rig for almost three years before going to a Jabberwocky. I never got more than half a dozen rides in before the EBB started creaking!?!? I found that using anti-seize instead of grease worked the best...I smeared it on both sides of the wedge, the wedge bolt and nut cylinder, and all around the shell.
    Squalor
    Wily?
    That should fix it.
    LP
    hispanic mechanic
    Quote Originally Posted by lanpope
    Wily?
    That should fix it.
    LP
    Ha! It's gonna be a bit before I can get the Wily repaired!
    Los
    www.swimba.org
