Check toolbox- Mtbr.com
Results 1 to 14 of 14
Thread: Check toolbox
    Just Ride!
    Reputation: kustomz's Avatar
    Check toolbox
    I am in need of a bolt for my Marzocchi MX Air 29 that is no longer available. Can the 29er crew check the bottoms of your junk drawers?
    what are the specs?
    SSolo, on your left!
    I know I don't have that bolt, but if you could post the specs too would help. I'm assuming you tried calling Marzocchi direct?
    Get off the couch and ride! :)
    Reputation: JoshM's Avatar
    If you can get the dimensions and material specs any decent machine shop would be able to make you something that will work.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by kustomz
    The arch to lowers bolt. The canti brake boss does the same job.
    mtbtires.com
    Just Ride!
    Just wanted something a little more slim than the stock canti-post.
    Dec 1998
    You can cut off the brake post part. Seen it done.
    mtbtires.com
    Pretty sure I have an extra set of those laying around...
    Mtn Biker Machinist
    Reputation: 1 cog frog's Avatar
    Dec 2004
    Quote Originally Posted by JoshM
    Yea for 10X the price! Shop rates where I work are $80/hr plus tools and materials! You could buy a whole bag for that much!
    frog
    Reputation: turkish_sp's Avatar
    Nov 2008
    Quote Originally Posted by 1 cog frog
    frog
    That's pretty expensive! I got four stainless steel cantilever brake bosses for 60 €
    Tommy:It's for protection.
    Turkish:Protection from what . . . zee Germans?
    veintinuevepulgadas
    Dec 1998
    Quote Originally Posted by turkish_sp
    These are specific to the fork. Holds the arch to the lowers with dual duty as the canti boss.
    A hacksaw to remove the brake portion and finish with a large drill bit to make a tapered countersink end. Done at near zero cost and 30 minutes of time.
    mtbtires.com
    Nov 2008
    Quote Originally Posted by shiggy
    I know, and I agree with you.
    I broke one of the canti boss from my Clark·Kent F14 and couldn't find one to replace it, so I had them CNC made.
    veintinuevepulgadas
    Single Speed Junkie
    Reputation: crux's Avatar
    Guy really wants bolts. I offered slicing them down and finishing on the lathe for a nice finish. See the other related thread.
    http://forums.mtbr.com/showthread.php?t=675542
    Just Ride!
    Quote Originally Posted by wesMAmyke
    I just need one if you happen to find them?
