Check out my new Ted (Wojcik) drawing!!!- Mtbr.com
Results 1 to 23 of 23
    Transplant
    Reputation: ekoostick's Avatar
    I want to make sure that my drawing is correct according to most common things with 29ers. I just send him an e-mail as I want to do an 80mm Reba and I don't think that the current drawing agrees with that. Am I wrong and is there any other measurements I should worry about? Thanks for any help!
    Squalor
    Yep -
    The axle to crown there is 438mm. It needs to be about 470mm for the 80mm REBA.
    Also make sure to ask for a little extra HT extending downward from the HT/DT junction to clear the pop-loc on the REBA.
    I am anxious to see this bike! I bet it will be sweet.
    Make sure to keep us updated.
    LP
    Work Shed...
    Reputation: Rootberry's Avatar
    That's gonna be a killer ride! BTW, how do you pronounce Wojcik??
    It's not hip hop, it's electro.....
    Transplant
    wo-chick I believe.
    TW Owner
    A guy from NYC that knew Ted was on a Western Spirit trip, he pronounced it WOE-jik.
    Reputation: edouble's Avatar
    this is my drawing...
    http://www.msnusers.com/p0cq291mpg9a...X29%5B1%5D.pdf
    im using a white bros. bw.8, does anyone forsee any problems?.
    EAST COAST
    CLYDESDALE
    DREADLOCKED
    STEEL RIDER
    two questions...
    Quote Originally Posted by ekoostick
    how did you post yours directly (i couldnt, no skills ) and how tall are you?.
    i posted mines also, but had to use a link.
    EAST COAST
    CLYDESDALE
    DREADLOCKED
    STEEL RIDER
    Reputation: MMcG's Avatar
    Jul 2003
    will a 5" headtube length make for a pretty tall front end on the bike?
    Well, proper Polish pronunciation would be Voy-Chick.
    Transplant
    Quote Originally Posted by Ricky J
    Yeah that could be it, I am not sure. All I know is that as long as you spell his name right on the deposit check, you can call him whatever you want
    Transplant
    Quote Originally Posted by edouble
    I am 6'2 with shortish legs (33" inseam") therefore the seattube is a little shorter then i normally ride but he thinks with the 29er and for endurance racing, it will work out pretty well.
    I had to take a screenshot (ctrl+print screen) and then edit it with photoshop. If you want to e-mail me your pdf to xcbiker @ comcast.net then I will edit it for you and post it and send you a .jpg (picture image). I cannot access your file as is though.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by MMcG
    It will be shorter when adjusted for the longer fork.
    mtbtires.com
    Dec 1998
    EDIT!: The BB is way too low for my taste (2.5" drop = ~11" BBH).
    oops - misfigured (no coffee!). 2.5" drop is a 12" BBH, which is OK. I still like higher.
    mtbtires.com
    Reputation: brant's Avatar
    Are you running a rigid fork?
    I'd move the BB up a bit. By 1/4 to half inch at least.
    Recovering couch patato
    Reputation: Cloxxki's Avatar
    2.5" drop = 63mm? KM's have 68mm drop, so it's nothing out of the ordinary unless you're a shiggy type that rides 190mm cranks full-on through rockgardens :-)
    Top tube looks short, but that's personal preference I guess.
    im 6ft 2in also...
    w/ a 34in inseam so were very close in size. ill email you the pdf.
    EAST COAST
    CLYDESDALE
    DREADLOCKED
    STEEL RIDER
    Shamisen Appreciator
    Quote Originally Posted by Rootberry
    Under your breath so no one can hear that you f'd it up.
    Sean Chaney :: Owner/Builder :: Vertigo Cycles
    Reputation: mtgoz's Avatar
    Dec 2005
    What's the build time?
    Jesus Is Coming, Everyone Look Busy
    Keith,
    Check your PM...
    wow, this hurts more than it used to.
    Transplant
    So many helpful responses! Well I got an e-mail back from Ted this weekend and he hadn't had his coffee when he had started the CAD. He said he is going to start from scratch and get me something this week that should be a bit more 29er and a little less rigid 26er. I will post when the new drawing comes in! Thanks again for the input guys!
    beer thief
    Reputation: radair's Avatar
    Dec 2002
    Keith, did you check with Ted to see how he feels about posting his CAD drawing on the 'net? I think you should.
    Transplant
    I am sorry to everyone
    Quote Originally Posted by radair
    I am sorry but I am taking down the drawing as its not my property to put there. I am sorry to anyone that I upset and didn't realize what I was doing. Thanks for the heads up Radair, I had no idea
    Quote Originally Posted by lanpope
    Yep -
    LP
    You might want to download the Reba spec here to check the fork clearance...
    Francois
