Page 2 of 2 FirstFirst 12
Results 101 to 117 of 117
  1. #101
    dvn
    dvn is offline
    Reputation: dvn's Avatar
    Quote Originally Posted by wickedmtb View Post
    Building up a 17.5 FR-202. I have a few question I need answered. I'm sure they have been pointed out somewhere before. Just to many pages to go through.
    I'm using spare parts I had around to save on money. I will be using a fox 34 ctd, 140mm travel. I will be lowering the travel to about 110mm. Question, will the head tube support a 110-120mm travel fork for light xc trail racing?
    Second question, what post to post disk brake adapter do I need to run 180mm rotor in the rear?
    Finally, frame calls for a 36.6 seatpost clamp. Will a 36.4 do, or will this effect the integrity of the seat collar? Thanks for the help in advance.
    Attachment 889867
    I can't answer the headtube question. I guess you'll find out. I don't know if there is enough room in the rear for a 180 rotor. Really no need for one for XC riding. I am running a KCNC 36.4 clamp with no issues.
    "Either way it doesn't really matter, I just got back from a bike ride."
    > dbhammercycle
  2. #102
    Mar 2012
    Thanks for the fast response. I checked frame with 180mm rotor. It will clear just fine, just not sure of what size post to post mount I need.
    Its good to here a 36.4 seat clamp will work. Thanks again.
  3. #103
    dvn
    dvn is offline
    Not positive, but it looks like you'll need one of these: New Avid Disc 40mm Post Mount Adaptor Fits 200mm Front and 180mm Rear Rotors | eBay
    > dbhammercycle
  4. #104
    Mar 2012
    Thank you. I thought that might be it. I have already placed an order for one. I just wanted to make sure if that was the write one. Guess I will find out soon enough.
  5. #105
    May 2014
    I just ordered an IP-256SL. This will be my first build from scratch. I will use some parts from my old 26" mixed up with some new parts. Thanks for all the info so far. I will likely run into some issues as I go along. Now it is a waiting game. ☺
  6. #106
    Nov 2014
    Quote Originally Posted by karmax View Post
    Hello
    I have been building up a FLX-FR-219 (frame and Fork). I am a bit concerned that the top bearing in the head tube is loose. The bearing is placed easily into the formed head tube channel. expansion nut and preload is firm and to torque specs.
    To those that have been building their frames - has the bearing required some force/pressure to place into the channel or have you encountered the similair issues?
    It may result in 2 options:
    1. Return/Exchange Frame
    2. Find slightly larger bearing (diameter)
    Any advice would be helpful
    I have the exact same issue with my FR-216. How did you solve the problem?
  7. #107
    Apr 2016
    Do I need to add any special grease to bottom bracket when installing, or to headset?
  8. #108
    Reputation: Epic_Dude's Avatar
    May 2010
    Quote Originally Posted by gleini View Post
    Typically headset bearings have a chamfer on the edge to help the bearing center into the bearing cup as you tighten down on the expansion which pulls everything together. Just make sure you apply some light pressure to make sure everything is aligned and together as you are tightening the headset.
  9. #109
    May 2010
    Quote Originally Posted by Roadie2mtb View Post
    Park Tools Polylube is a good all around grease for bottom brackets and headsets.
  10. #110
    Apr 2016
    What bottle cage bolts should I get? I think they all fit, but I've seen different lengths, and different types like alloy, ti, stainless
  11. #111
    Dec 2017
    Now that the thread is a few years old anyone still riding their carbon bike? Any issues with the frame?
  12. #112
    Reputation: NazZaR's Avatar
    Jul 2013
    Quote Originally Posted by stykthyn View Post
    Nope
    XMCarbonSpeed CS-057 29er custom build
    https://www.strava.com/athletes/2293724
  13. #113
    Mar 2015
    Seeing as there are 1000 page threads and an entire forum dedicated to Chinese carbon bikes, I would say Yes.
    I built one in 2015 and sold it to my coworker who still enjoys it. I ride a few carbon Giants now, but would have built another Chinese hardtail 6 months ago had I not found a new Carbon Giant XTC frame for 700 bucks.
  14. #114
    Apr 2016
    Built mine in 2015 still riding great. Hardtail. just riding easy trails.
  15. #115
    Jul 2013
    I recently purchased a 2017 Scott Spark RC 900 WC, but still not ready to part with my Chinese hardtail 29er.
  16. #116
    Reputation: RobLyman's Avatar
    Finished mine in early October of this year. 292 miles on it so far.
  17. #117
    Apr 2016
    Thinking about selling my hardtail from XM carbon speed 057, with light bicycle carbon wheels, Shimano XT 1x11 Black with neon green.
  1. Chinese Carbon 29er
    By crashplayer19 in forum 29er Bikes
    Last Post: 1 Week Ago, 07:10 AM
  2. building up a Chinese hardtail.
    By facelessfools in forum Weight Weenies
    Last Post: 09-22-2014, 03:20 PM
  3. Building Chinese Carbon 29er Wheels, ask anything
    By Adim_X in forum Wheels and Tires
    Last Post: 11-28-2012, 10:15 AM
  4. Any re-building tips for a 2009 RS SID Race fork?
    By IRONMAN1518 in forum Shocks and Suspension
    Last Post: 05-03-2012, 06:15 PM
  5. Tips advice on building hip jumps for first time
    By Scythe in forum Trail Building and Advocacy
    Last Post: 01-04-2012, 04:49 AM
Members who have read this thread: 39
