Big fork hardtails
Printable View
  • 08-26-2010
    kaiser2
    Big fork hardtails
    Quite fancy something along these lines for my next bike. So what's available? Really like the look of the Canfield Yelli and the Chumba HX2. The new Vassago looks promising too. Anything else out there thats suitable for 100/120mm forks with slack head and tight chainstays?
  • 08-26-2010
    Ryan G.
    Banshee Paradox
  • 08-26-2010
    perttime
    Sinister Simon Bar, if you can find one.
  • 08-27-2010
    kaiser2
    Both very nice:)
  • 08-27-2010
    pulsepro
    Banshee Paradox
  • 08-27-2010
    rockcrusher
  • 08-27-2010
    cycljunkie
    Voodoo Soukri
  • 08-28-2010
    kaiser2
    Anything else out there in steel?
  • 08-28-2010
    nitrousjunky
    The Canfield Nimble 9 is still coming and is suppose to be the same geometry as the Yelli Screamy.
  • 08-28-2010
    Blaster1200
    Here's something I just built:
    67.5 degree head angle with the TALAS 29 set at 120 mm
    12-1/16" bottom bracket height with fork at 120 mm
    16-5/8" chainstays
  • 08-28-2010
    Enel
    16-5/8" chainstays
    Yowza. Nice job. That bike deserves its own thread. Did you do the frame fab yourself?
  • 08-28-2010
    mtroy
    Yeah, there is one on another forum. It is, I think, the best looking bike of its kind I have seen.
    Perhaps the builder will share the link, it might be presumptuous for me to post it for him. He did it himself, from what I read.
    He could build me one too.:thumbsup:
  • 08-28-2010
    Blaster1200
    Thanks. I started a new thread. Yes, I did build it myself.
    http://forums.mtbr.com/showthread.php?t=646963
    mtroy,
    Yes, I'm 2wheel-lee on STR
    http://www.socaltrailriders.org/foru...r-content.html
  • 08-29-2010
    kaiser2
    That build is awesome:cool: will need to have a good read through the thread.
    I never realised the nimble 9 may share the geometry of the Yelli, the HT looks steeper than the figures suggest.
  • 08-29-2010
    insanitylevel9
    ooohhhh they will be back i just got word from dane there making bikes again in the spring im so exsited
  • 08-29-2010
    flymybike
    Head Angles on both the Nimble 9 and the Yelli Screamy are 69 degrees with a 100mm fork. 80 would be 70 degrees and the 120mm forks will be 68 degrees. The Nimble 9 CS adjusts from 16.25 to 16.75 and the Yelli Screamy CS is 16.7", both three ring compatible which is what makes these bikes special.
  • 08-29-2010
    wyatt79m
    When is the yelli gonna be available ???
  • 08-29-2010
    kaiser2
    Cool, lots of good numbers:)
    How would you say the ride differs between both? Classic steel vs Alu? Or is there more to it? What were the differences in the design remit?
  • 08-30-2010
    flymybike
    The Yelli Screamy will be in on the 7th, shipping around the 10th.
    The two frames share the same geometry, the aluminum Yelli is geared and has a tapered headtube to take advantage of the stiff nature of aluminum. Great for most everyone however the Nimble 9 being steel gives the ride a much softer feel. To take advantage of that we used radial seatstays to absorb more of the vibration and soften harder impacts. People looking for a stiff frame would want a Yelli, anyone looking for a compliant hardtail that won't beat you up as much, the Nimble 9 is the way to go.
  • 08-30-2010
    Clink
    What's the eta on the Nimble 9 then? and how is it different to the original prototypes?
  • 08-30-2010
    flymybike
    Chris is at Eurobike sorting out the details on getting the Nimble 9 built. ETA is unknown till he gets it worked out but likely to be spring. We are hoping that nothing will need to change on it from what you've seen.
  • 08-30-2010
    Clink
    Yey! :-)
  • 08-31-2010
    kaiser2
    Both the Canfield and Paradox are looking good:) and both available in the UK. Bit premature comparing but what are initial impressions between the two?
  • 08-31-2010
    perttime
    I don't think many have impressions on the Yelli yet. People generally seem to like the Paradox. All else is still speculation.
