Best Tire Setup? Help-Tubeless or Tubes?- Mtbr.com
Results 1 to 3 of 3
    What is the best 29er Tire Set-Up?
    After reading this message board for many months, I’ve built a 29er. What's the best tire/tube/tubless set-up? I'm leaning toward Igniter's with Stans?
    featherweight clydesdale
    Reputation: Fattirewilly's Avatar
    Dec 2001
    Quote Originally Posted by BiggDaddy
    You'd probably get more help if you provide a little more info such as your location/conditions (wet, dry, rocky, rooty, thorns??) and your intended use (trail vs XC racing).
    Good point. I'm looking for a 2.1 or wider all around tire. I'm in Oklahoma and the trails vary from sand, gravel, rock garden, rooted, technical, etc. You name it, we have it. An all around setup but a little more on the aggressive side. I race our series so something that won't cause DNF's. Weight isn't a real issue as I can always shave weight off my arse.
