• 09-09-2009
    247
    Best tire combo for roots and rocks.
    I was using Exiwolf's(2.3) on front and back on my G.F. Paragon. Then started slipping and sliding when it got wet out on the trails. I now have a Bontragre XDX(2.1) on the front and a Michelin AT(2.00) on the rear.
  • 09-09-2009
    godfather
    Depends on the bike and type of riding (lots of climbing, racing, descending, xc, am, dh?). It's tough to beat the Minion DHF Super Tacky for all around grip, wet or dry. It would be too heavy for xc and racing in my opinion, but for dh or even am it could be the ticket. Next tires I'm trying are the new Continentals, Der Kaiser for DH and Rubber Queen for am.
  • 09-09-2009
    knottshore
    You may need very strong tire levers to install the Minions, Conti Der Kaiser or Rubber Queens on the 29" Rims....
  • 09-09-2009
    godfather
    :D I've been bouncing around between different forums today. I guess I thought I was on the Wheels and Tires forum when I replied to the thread. My bad, but on a 26" rim they are sweet!
  • 09-09-2009
    TigerRider
    I've been using Bonty XR 2.2 rear, ACX 2.2 front for all around riding and this combo works well on rocks and roots in the midwest. the front can get a bit sketchy on wet rocks/roots, but the XR works very well as a rear tire. Not uber light (600-660 g) but they do the job well.
  • 09-09-2009
    knottshore
    No worries, were all human here... I just got a kick out of it...
  • 09-09-2009
    rojogonzo
    the xr works ok for me as long as there no snot
  • 09-09-2009
    CB2
    When it gets wet, I'll either use Ignitors f/r, or Ignitor (r), Nevegal (f) depending on how rough the course is.
    This is a dilemma for me right now:
    For Landmine this weekend do I risk it and leave Race Kings on or go to the Ignitor / Nevegal combo pack?
  • 09-09-2009
    jcaino
    WTB Stout should be pretty good...
  • 09-09-2009
    247
    Doing alot of XC riding in the Northeast. I'm gonna try a Stout in the front, and the Bonty in the back, especially for this Fall with the cold and wet... Thanks everyone...
  • 09-09-2009
    flyag1
    I don't think there is a better tire as far a grip than the Nevegals but they want do anything positive for you RR and they are heavy. And if you are a plow-er like me, get ready for some pinch flats.
  • 09-10-2009
    wv_bob
    FWIW, I'm having problems with the front Ignitor on my bike washing out. Last time out, veering over to share the trail with oncoming traffic put me on my butt thanks to damp grass.
    The rear sticks like glue though.
  • 09-10-2009
    mo0se
    There are no tires that grip on wet rocks, roots, etc. It comes down to the rider in those conditions.
  • 09-10-2009
    flyag1
    So true: but some tires are better than others in wet. IMO stay away from Crosmarks, Ignites, XDX, and all Schwalbes if it's wet. Nevegal stick-e is much better in the wet and the Maxxis Ardent is OK if you're tubeless and run low pressure. But as Moose said, riding in the wet puts a lot of pressure on the rider no matter what tire you run.
    Choose your line carefully...
  • 09-10-2009
    xmangox
    The guys at my local LBS just set me up with a 2.4 mountain king up front, and a 2.2 mountain king in the rear on my 29er FSR Expert. does this sound like a good combo? Previously I've run 2.2 Mountain Kings with Black Chili & Protection sidewalls on my 26" FSR XC.
  • 09-10-2009
    OilcanRacer
    amen to that!!
    but with more size and better knobby shape some are better. i like the rampage over the nevegal just because it is slightly wider. at lower psi it can grip on wet stuff and is a tough tire.
    the ird firepro is super knobby and can hookup on wet stuff, but sometimes it works to your disadvantage on slick roots.
    the michelin at xc is a great all around performer that will work at lower psi on wet.
    racing ralphs 2.4 feel like a slick in the wet even at low psi
    furious freds are slicks.
    weirwolfs are not half bad at lower psi, i am having good results on my SS. at higher psi forget it.
    all the contiental tires didn't work for me in any wet situation.
    i will try the geax barro race folding tire and the bigger maxis ardent next, but they are dry tires so not seeing it working in the wet.
    all these opinions are "IMO" on wet roots/rock and slick stuff(not mud), you might have varying millage, i weight 155lbs, 5'10", riding on vassago rigid/hartail, jet9, access SS hardtail.
  • 09-10-2009
    UnitedWeRide
    This is the combo I am running currently on my SS HT and so far the front has done me well in the dry, the rear I am still in up in the air about, but I havent ridden the combo in any wet conditions yet but will be soon as the weather changes. I have a few slips here and there on the rear in loose over hard conditions and washed out the front on a few occasions but it recovers very quickly with minimal effort. I am tubeless up front and tubed in the rear. Once I get my new rim tape ill be tubeless in back as well and will give more feedback.
  • 09-10-2009
    sean salach
    be careful with the stout if it's really cold. or any tire with really soft rubber for that matter. they stiffen up quite a bit and become slippery. i'm talking <20* F here.
  • 09-10-2009
    clydeone
    XDX on slightly damp roots - and it feels like someone came along and greased them all :madman:
    add that to feeling a little off (i.e. sloppy with picking lines, overreacting with the brakes) = bad day on the bike --- of course its still better then any day off the bike. :D
    of course my entire experience on a 29er is on these tires
    as long as its dry I have little complaint with the tires
    Sounds like best choice to try would be Rampage F Ignitor R
  • 09-11-2009
    craigshaf
    I run the MK 2.4 on the front of my RIP9. Love that in the front. Replaced a Rampage. Liked that too I guess.
    Tubeless on Stans ZTRs front and back.
    Ran a Rampage in the back until I tore it up running too little pressure. Just put a small block 8 on the back that I'll probably run through the rest of the dry season. Love the speed of the small block, but not getting the traction I got from the rampage on technical rock climbs and real loose dirt. Going to try to turn it around so the ramps face backward. Cost a little bit of rolling resistance but might get to the traction I like.
    BTW - I've got 2 never used 29x2.2 Conti MKs. I'm not going to use them. Want to trade me for something else? I'll need a wet weather rear.
  • 09-11-2009
    joedirt24
    I run Ignitors front and rear. I dropped the pressure from 35psi to 30psi and it helped alot. I have run Crossmark and Ardent in the rear I think the Ignitor is the better of the bunch.
  • 09-11-2009
    Mr Pink57
    The Race King makes a decent rear tire, I would imagine all you would need is a beefier front to help you out. Something like a Ardent, Nevegal or Rampage.
    pink
  • 09-11-2009
    clydeone
    It's amazing the difference 24 hours of drying makes for the XDX -- Completely different day today on the exact same trails I think I felt the rear slide twice -- once in a small patch of mud and once while hammering up a hill while climbing -- I didn't even dab a foot once, whereas yesterday I was off the bike as much as I was on it -- or so it seemed.
  • 10-25-2009
    scsamoyan
    mk is a wet weather tire i think.
