Best carrier for pick up?- Mtbr.com
Results 1 to 24 of 24
    Getting a new 29er (probably a Tallboy) and I have a Ford Ranger (regular bed). What's the best way to transport the bike without messing with removing the front wheel?
    29er
    1up usa rack
    I don't have a hitch on the truck so I'm looking for a way to carry it in the bed.
    Reputation: thickfog's Avatar
    Oct 2010
    http://biketubes.blogspot.com/2010/0...o-get.html?m=1
    Bike stays clean, safe and will never fall off of a rack or get rear ended.
    What keeps the InstaGator from falling over going around corners?
    it has some straps that lock into the tailgate or, I have mine bolted to the bed head rail. I also put one in a buddies new Tundra and attached it to the Toyota bed rail system.
    Oct 2010
    http://biketubes.blogspot.com/2010/0...ck-m:rolleyes: ight-have-to-get.html?m=1
    Oct 2010
    Quote Originally Posted by PillsonWheels
    That's pretty neat.
    Watched the video on the Instagator. Looks pretty cool. Unless your tailgate locks, though, you'd need to lock it up with a cable I assume.
    Reputation: SeaBass_'s Avatar
    2X8 with a couple of front fork clamps screwed in. Trim it with a sawz-all to fit the contours of the front of your bed. Easy in, Easy out.
    Reputation: Noclutch's Avatar
    Jun 2010
    I use moto tie-downs, but on the stem instead of bars. It takes very little load to secure it- like less sag than body weight does, so I'd have a hard time imagining it being damaging in any way. Sometimes a bungie through the back wheel too. Cheap too.
    Lay it down on the non-drive side in the bed....presto!
    Reputation: dvo1's Avatar
    Quote Originally Posted by ssalmons
    Agreed. What is the point of a truck if you don't use the box as intended.
    Quote Originally Posted by Noclutch
    This is what I use. Can get six bikes in the back of a duramax short bed. When it's just me, I throw it in the back on the non drive side like others mentioned. Cheap quick and very painless. If I'm traveling, then I run a lock cable thru the bike and attach it to the cleats of the tie downs.
    Although, the Dakine Pick-up Pad looks very interesting.
    Check out this rack,
    http://www.pipelineracks.com/
    El Pollo Diablo
    Reputation: SnowMongoose's Avatar
    Feb 2007
    Pickup Pad + one ratchet strap, good times.
    Reputation: Vecsus's Avatar
    Quote Originally Posted by No-throttle
    Don't spend $180 on that. Using pvc pipe you can make something like that for less than $20. I have something similar in my truck for 2 bikes. Took about 30 minutes to make. Been working perfectly for 3 years now.
    Vecsus
    HTFU or STFU
    Whatever kind of rack you get, you better have it delivered. I'm sure you'd be flumoxed wondering how the devil you'd get it home from the store.
    Touché!
    I do 2 things: I use ratcheting straps (6.99 or so/pr. from Harbor Freight) attached to my handlebars by that rubber-coated hook, or I just throw it into the bed. I put it drive-side down b/c I don't want to take a chance on messing up brake system. Am I wrong to do it that way?
    I also use my daughter's VW Beetle (so I DID have ulterior motives for not letting her take it to college), because my daily-driver won't hold my bike unless the top's down.
    Reputation: smaxor's Avatar
    Dec 2004
    29er
    Quote Originally Posted by Traktor
    took me a second
    but
    trail rat
    Reputation: slocaus's Avatar
    Plenty of ideas here; thread has been going since July 2006. Sorry you are not the first......
    "The physician heals, Nature makes well" - real fortune cookie
    CCCMB trail work for trail access - SLO, CA
