Best carrier for pick up?
Printable View
  • 12-20-2010
    PillsonWheels
    Getting a new 29er (probably a Tallboy) and I have a Ford Ranger (regular bed). What's the best way to transport the bike without messing with removing the front wheel?
  • 12-20-2010
    Dan GSR
    1up usa rack
  • 12-20-2010
    PillsonWheels
    I don't have a hitch on the truck so I'm looking for a way to carry it in the bed.
  • 12-20-2010
    thickfog
    http://biketubes.blogspot.com/2010/0...o-get.html?m=1
    Bike stays clean, safe and will never fall off of a rack or get rear ended.
  • 12-20-2010
    havaclu
  • 12-20-2010
    PillsonWheels
    What keeps the InstaGator from falling over going around corners?
  • 12-20-2010
    Dan GSR
  • 12-20-2010
    havaclu
    it has some straps that lock into the tailgate or, I have mine bolted to the bed head rail. I also put one in a buddies new Tundra and attached it to the Toyota bed rail system.
  • 12-20-2010
    thickfog
    http://biketubes.blogspot.com/2010/0...ck-m:rolleyes: ight-have-to-get.html?m=1
  • 12-20-2010
    thickfog
    That's pretty neat.
  • 12-20-2010
    PillsonWheels
    Watched the video on the Instagator. Looks pretty cool. Unless your tailgate locks, though, you'd need to lock it up with a cable I assume.
  • 12-21-2010
    SeaBass_
    2X8 with a couple of front fork clamps screwed in. Trim it with a sawz-all to fit the contours of the front of your bed. Easy in, Easy out.
  • 12-21-2010
    Noclutch
    I use moto tie-downs, but on the stem instead of bars. It takes very little load to secure it- like less sag than body weight does, so I'd have a hard time imagining it being damaging in any way. Sometimes a bungie through the back wheel too. Cheap too.
  • 12-21-2010
    ssalmons
    Lay it down on the non-drive side in the bed....presto!
  • 12-21-2010
    dvo1
    Agreed. What is the point of a truck if you don't use the box as intended. :skep:
  • 12-21-2010
    2Slo4U
    This is what I use. Can get six bikes in the back of a duramax short bed. When it's just me, I throw it in the back on the non drive side like others mentioned. Cheap quick and very painless. If I'm traveling, then I run a lock cable thru the bike and attach it to the cleats of the tie downs.
    Although, the Dakine Pick-up Pad looks very interesting.
  • 12-21-2010
    No-throttle
    Check out this rack,
    http://www.pipelineracks.com/
  • 12-21-2010
    SnowMongoose
    Pickup Pad + one ratchet strap, good times.
  • 12-21-2010
    Vecsus
    Don't spend $180 on that. Using pvc pipe you can make something like that for less than $20. I have something similar in my truck for 2 bikes. Took about 30 minutes to make. Been working perfectly for 3 years now.
  • 12-21-2010
    Traktor
    Whatever kind of rack you get, you better have it delivered. I'm sure you'd be flumoxed wondering how the devil you'd get it home from the store.
  • 12-21-2010
    expostdelirium
    Touché!
    I do 2 things: I use ratcheting straps (6.99 or so/pr. from Harbor Freight) attached to my handlebars by that rubber-coated hook, or I just throw it into the bed. I put it drive-side down b/c I don't want to take a chance on messing up brake system. Am I wrong to do it that way?
    I also use my daughter's VW Beetle (so I DID have ulterior motives for not letting her take it to college), because my daily-driver won't hold my bike unless the top's down.
  • 12-21-2010
    smaxor
  • 12-21-2010
    Dan GSR
    took me a second
    but
    :lol: :lol: :lol:
  • 12-22-2010
    slocaus
    Plenty of ideas here; thread has been going since July 2006. Sorry you are not the first...... ;)
