BB size on Karate Monkey- Mtbr.com
    What is the size of the bb on a KM. Thanks in advance.
    Beau
    Big Wheel Homer !!
    Reputation: cruzthepug's Avatar
    Quote Originally Posted by bbethel
    Beau
    Bottom bracket shell: 73mm wide, 1.37x24t
    http://www.surlybikes.com/karatemonkey.html
    I saw that on the surley site, but what is the second measurement in mm?
    Down South Yooper
    Reputation: Plum's Avatar
    Sep 2004
    It's the thread/pitch designation
    Basically, get an english thread BB that has a 73mm shell width, or one that's compatible with both shells (68 or 73mm). The bb axle width will depend on your crankset, different cranks have different Q factors, requiring different widths of axles. To complicate it further, you may opt for a different width axle if you're losing a couple rings, say in a singlespeed setup, the clearance for the small ring may allow a slightly shorter axle.
    There are three types of (relatively) common BB types, English (most common), Italian (less common) and French (I've never seen one). They differ in diameter, thread pitch, thead direction, etc. Most newly produced frames will take an english BB. They're so common, that if you don't specify, you'll end up with english. I would imagine that anything else would be a special order...
    Plum
  1. Welcome, here's your 29er FAQ thread!
    By ncj01 in forum 29er Bikes
    Last Post: 06-20-2012, 01:56 PM
  2. Karate Monkey in black and Sexy!
    By vcyclist in forum 29er Bikes
    Last Post: 12-03-2004, 01:21 PM
  3. Things to know before building up a Karate Monkey
    By SpinWheelz in forum 29er Bikes
    Last Post: 11-05-2004, 03:34 PM
  4. Lightweight, durable ISIS BB?
    By 1speed_Mike in forum Weight Weenies
    Last Post: 09-01-2004, 01:07 PM
  5. For fun: Dirt Rag's Monkey review
    Last Post: 04-27-2004, 10:38 AM
