Axle to crown for G2 Reba?- Mtbr.com
Results 1 to 3 of 3
    Does anybody know the axle to crown length of the G2 Reba (Fisher/Trek-specific geo with 51mm offset)?
    The regular 29" Reba is 506/486mm while the G2 should be longer, but I've searched far and wide the web for an exact figure to no avail...
    Reputation: boomn's Avatar
    I only recently learned this too, but these fork companies measure axle to crown parallel to the steering axis, so offset doesn't actually change the a2c. I always assumed they measured out at an angle directly to the axle location
    Here is a technical drawing of one of the Reba 29er models, and here is an example from Fox too
    You are right, but I think the G2 is different also in length, not only in offset. For example the Fox F29 G2 100mm is 510 a to c vs. 500 for the standard one.
  1. Axle to Crown for Reba RLT Ti 140/120mm?
    By Lugboot in forum 29er Bikes
    Last Post: 06-30-2011, 04:06 AM
  2. Reba RLT TI (reduce axle to crown)
    By ingenmtb2 in forum General Discussion
    Last Post: 04-10-2011, 02:00 PM
  3. Replies: 5
    Last Post: 12-29-2008, 04:32 PM
  4. Axle --> Crown Reba
    By Dex11 in forum Shocks and Suspension
    Last Post: 11-19-2005, 05:22 PM
  5. Reba axle - crown height
    By Emilio in forum Shocks and Suspension
    Last Post: 11-05-2004, 03:11 AM
