Anyone installed a Sram xx crank with 37t in front?- Mtbr.com
Results 1 to 10 of 10
    Hi, I just order a Sram XX crank, it comes with a 42-28. I donít think I can move a 42 so I decided to see if anyone makes a smaller chaingring and there is a company that makes a them.
    e thirteen 4x120 bcd guiderings
    Have anyone use any of this chaingrings, I am looking at the 37t.
    Thank you.
    Oct 2011
    What kind of riding are you doing that you wouldn't be able to move a 42?
    Well i have a 36 chainring now and went going uphill sometimes I have to stand up to make it, I would think a 42 would make it a lot harder to climb. I mountain bike, not a great deal of climbs but I think a 36 is a perfect size for me, Sram XX does not come on 36, the smallest chainring I have seen that work on the Sram XX is the 37 by e-thirteen.
    so don't use the 42T on climbs... there are two chainrings for a reason
    2x
    FSA 2 x 9 conversion. 27/39 works great!
    You lose the XX quick shifting capabilities when you switch to other chainrings.
    Quote Originally Posted by D1PHAM View Post
    In addition to that I convert to only one Chainring in front. I don't have a sifter or a front derailleur.
    So, have anyone ever done this, install a smaller chaingring on the Sram XX Crank (smaller than 39)
    Quote Originally Posted by rcruz2525 View Post
    Aluminum 80bcd 4 Bolt Chainrings
    I misunderstood your question above. If you are going to use just a single ring up from (e.g. 1x9 or 1x10) then you can purchase a ring from HBC install it on the inner side and call it day.
    Yes, Thank you
    That will solve my problem and I can get it in 36T
    Thank you for the help...
  1. sram X-9 front derailleur for a 2 ring crank
    By Roc1 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-09-2011, 04:02 AM
  2. Replies: 15
    Last Post: 02-06-2011, 06:42 PM
  3. Superfly 100 with SRAM XX Installed...
    By stratmosphere in forum 29er Bikes
    Last Post: 06-17-2010, 06:44 AM
  4. Sram XX crank with Shimano XT shifters and front derraileur
    By craigswardmtb in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-24-2010, 12:20 PM
  5. Sram XX front Derailleur on std crank 2x9
    By mimi1885 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-11-2010, 06:32 PM
