Anyone ever use Shimano Nexus Hubs?- Mtbr.com
Results 1 to 9 of 9
    Shimano makes a rear internal shifting hub, 3 and 7 speeds. You can order them with internal drum brakes. I'm considering using the 3-speed hub but wonder about its durability. Anyone use these?
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    They cant take it..
    Quote Originally Posted by le Coq Rouge
    youll destroy it..riding dirt. Rohloff is the only game ..
    GT is using the Nexus hub, albeit in the mid section of the bike and not as a rear hub, as a drivetrain for their internal gear'd DH bike.
    I've used the 7 speed for skatepark riding. Things are tougher than most people give them credit for.
    Kill your... television
    Reputation: motoman711's Avatar
    I have a 7 speed on my cruiser. It feels like I am pedaling in oatmeal all of the time.
    "Whereas Motoman's bike looks like an industrial, TinkerToy experiment gone horribly wrong." - Aquaholic
    Ti
    Misfit
    highly visible
    Reputation: GlowBoy's Avatar
    Sram
    My KM is set up with a 3-speed SRAM DualDrive Disc hub. Yes, Disc. Although this hub was designed to be used along with a derailer in a 3x9 system, you can also (as I have done) put a single BMX cog on it with lots of spacers, and run it as a pure 3-speed with no derailer nonsense. I'm in my second winter of commuting on this setup, and it's held up beautifully with zero maintenance other than occasional chain lubes. This hub is expensive, typically $200-250, but to me it's been worth every penny.
    It's also turned out to be very efficient (I think SRAM may use a lighter weight oil), easily comparable to a derailer system when the chain is fairly clean -- and much more efficient than a derailer with a dirty chain. Internal gear hubs vary widely in efficiency - the following journal includes an exhaustive study: http://www.ihpva.org/pubs/HP52.pdf. Reportedly the new Shimano 8-speed Nexus hubs are all substantially more efficient than the 7-speed ones (which were awful), and the Red Stripe versions of the 8-speed hubs are more efficient yet.
    I know someone who broke a SRAM hub mountain biking, but he's a very aggressive rider who does lots of jumping, and snapped the axle. Otherwise I think it would hold up just fine under recreational mountain biking as long as you are careful not to shift under heavy power. I would highly recommend using an indexed shifter designed for a 3-speed rather than some old friction shifter you might have lying around.
    "People like GloyBoy are deaf. They are partisan, intellectually lazy & usually very angry." -Jaybo
    Reviewer/Tester
    Reputation: Rainman's Avatar
    No good
    One of my friends who is from Canada but lives here in AU "crunched" his Shimano 8 speed Nexus hub after a week of dirt and city riding. He is about 6'2 and the hub broke when he was riding it on the road on the way to a trail ride.
    Of course Shimano replaced it, but he got rid of the new hub and purchased a Rohloff.
    I don't think that the Nexus is up to offroad riding, it can't take the strain. I had the seven speed version for a while on a rigid cross bike, but after a few rides it started to make grinding noises, so I took it back to the shop and they replaced the hub. I sold it immediately.
    I would love to see Shimano produce an 8 speed offroad hub that was strong enough to take a bashing like the Rohloff does, but can't see that happening in the near future, unfortunately.
    R.
    It is inevitable ...
    Reputation: itsdoable's Avatar
    I've used 4 shimano Nexus, one SRAM DualDrive 3-speed, and several Rohloff's.
    1st one was a Nexus 7s - lasted a few months on a mtb before the half-shaft broke.
    2nd one was the warrenttee replacement, bike was stolen after 2 months.
    3rd one came on a cruiser townie, still working.
    Then I got the DualDrive, used off-road and it still lives, but it's sounding pretty gritty.
    4th was the new Red-Band Nexus 8s - suposedly stronger, with needle bearings. I was going to test it on trails again as it sounds like it would survive off-road. But when it arrived, my mother-in-law needed a new bike, so it ended up on her new ride. I don't mind, it gets ridden every day. Have not got another one yet, they are not easy to come by in these parts.
    My Rohloffs have been fine all along...
    Reputation: Joe1946's Avatar
    Dec 2005
    There is also the Freeride Hubs.
    http://www.freeridehubs.com/index.html
