• 01-30-2010
    Neptune
    Anybody running a bigger rotor (180mm) on rigid carbon forks?
    Have a White Brothers Rock Solid (465mm a-c) on its way to me and will be building up a new 29er SS (my first big wheel rig). I'm trying to build this largely from the parts bin and have I.S. calipers (the WB Carbon fork is post mount). I can get an adaptor, but it requires me to run a 180mm rotor. The WB folks say 160mm max. Is anybody running a bigger rotor than 160mm on this fork? What's your experience?
  • 01-30-2010
    thefuzzbl
    im running a 180 SLX on my origin8 carbon fork, ive had no issues with it.
  • 01-30-2010
    Guitar Ted
    I have run several carbon forks on different bikes with 180mm rotors on most. The Rock Solid I rode for several months had a 160mm rotor.
    Bigger rotors seem to set up brake shudder easier, The fork blades can oscillate pretty severely on some set ups. I imagine this is what they are trying to have you avoid doing.
    The best fork with 180mm rotors I have used is On One's Carbon Superlight fork. The Rock Solid is a fine fork, but even I could get brake shudder with a 160mm rotor. I wouldn't think a 180mm would make that better. ;)
    I would swap out the rotor and get an adapter for the 160mm rotor myself, but I don't think it would be the end of the world if you used a 180mm rotor with that fork. You just might experience a pretty bad shudder on really hard braking, so be careful with that.
  • 01-30-2010
    Neptune
    Good advice. I get occasional shudder on my cross bike. Annoying as hell, but not the end of the world. Might start with the 180 and change it out later. Thanks!
  • 01-31-2010
    Schmucker
    The shudder on your cross bike is typically due to the steerer mounted hanger instead of a fork mounted hanger.
    On One's fork has no rotor size limit. I have that and the Niner fork. I'll be getting a higher quality disc brake and using a 160 for the Niner fork.
  • 01-31-2010
    Markenduro
    Sell it and buy the on-one carbon rigid fork, I ran 203mm rotor in mine with no issues
  • 01-31-2010
    rojogonzo
    windcutter 180 on a rock solid for over a year with no problems at all.
  • 01-31-2010
    DirtDummy
    Avid Juicy 180s on WB Rock Solid. I do get chatter under hard braking.
  • 01-31-2010
    slsl123
    I run a 180mm rotor with bb7's on an "Exotic" carbon fork which seems to be the same fork as the White Bros and Origin8 - no chatter/shudder, no issues. Run it - you can always change it out later.
  • 02-01-2010
    grnamin
    I'm running a 180mm Formula rotor on my Niner Carbon fork despite the 160mm limitation and I haven't experienced any issues and the 180's help quite a bit when I go downhill (215 lb. rider).
  • 02-01-2010
    slannon
    180MM on a Pace RC31- No problems, no chatter- Fork flexed backwards with a 160 and a 180- Stops better now - 190+ lbs.
  • 02-01-2010
    mtsmith
    BB7's with a 180 rotor on a Origin 8 fork, it flexes a bit but i have never experienced it "shudder" other than brake rotor noise occasionally
