• 05-27-2019
    Alias530
    Any other bikes I should be considering?
    I have a V1 Evil Following and just kind of have an itch to get a new bike. It's the best bike I've ever owned but I'm ready for something new if all the right boxes are checked. It's always been just a hair too small for me. I'm 6'6" and would like something with at least 630mm stack, 29" wheels, and 115-140mm rear travel. I also want something that pedals well—I don't want to ever have to flip a lever to climb trails and no room for a water bottle *inside* the front triangle is a deal breaker.
    I'm considering the Santa Cruz Hightower (non-LT), Pivot Switchblade, and Ibis Ripley V4 (in no particular order).
    Ruled out:
    Pivot 429 Trail - stack too low
    Stumpjumper - not a fan of FSR, seems to need the bandaid of a firm shock to climb well
    Trek Fuel - stack too low
    Yeti SB100/130 - sooo many threads about cracked frames. That and the extra maintenance of the Switch system is enough to turn me off.
    Am I missing anything?
  • 05-27-2019
    pOrk
    Salsa Horsethief
    120/140
    29”
    Tall stack - 640mm XL
    Split pivot pedals well (DW design)
    I like mine
  • 05-28-2019
    starre
    Maybe:
    GG Trail Pistol
    Spot Mayhem
    Good luck!
  • 05-28-2019
    Robik
    Pole Stamina 140
    Sent from my Pixel 3 using Tapatalk
  • 05-28-2019
    Legbacon
    Ibis Ripley.
  • 05-28-2019
    Alias530
    Originally Posted by Legbacon View Post
    Ibis Ripley.
    That’s on the list I have in the first post :)
    Ripley, Hightower, Switchblade
  • 05-28-2019
    Legbacon
    More coffee.
  • 05-28-2019
    MSU Alum
    Trance 29 Pro 1 (because it has the DPX2).
  • 05-28-2019
    telejefe
    I am 6'5" and the XXL Fuel is the best fit of any bike I have ever riden (going on 30 years). Stack is 650. At 6'6" you owe it to yourself to try some proper big bikes. The Fuel is decent. The new version due in a month may be better....
    GG have always interested me for TT, Reach, and Stack.
  • 05-28-2019
    Vespasianus
    The Ripley is short. 6'6" might be too small, even in XL. You might need a XXL bike.
  • 05-28-2019
    skiahh
    Smuggler?
  • 05-28-2019
    Alias530
    Measurements are all a little bigger than my Evil if I remember right. I will compare again before purchasing.
  • 05-28-2019
    MSU Alum
    My son is 6'2" tall and fits nicely on a Ripmo, if that helps with comparisons to the Ripley.
  • 05-28-2019
    telejefe
    I would also wait for the new Hightower to hit the street before making a decision.
  • 05-28-2019
    acedeuce802
    GG Trail Pistol or Smash
  • 05-28-2019
    Alias530
    Yea I think a new Switchblade is probably on the horizon too
  • 05-28-2019
    Blatant
    I've owned a lot of the bikes mentioned, in XL and I'm 6'2, 34 inseam, +2 ape.
    Assuming you have normal limb proportions at your height, I seriously can't imagine any XL bike truly fitting you properly. Except the GG Smash, which I didn't like personally from a suspension standpoint, but it'll be the right size.
    You really should demo some XXL stuff just to see.
  • 05-28-2019
    Tystevens
    Not to hijack, but what didn't you like about the Smash suspension?
  • 05-29-2019
    CWnSWCO
    The Guerrilla Gravity stuff would be good for your size.
    Revel Bikes Rascal is sweet, but don't know if it'd be big enough for you.
  • 05-29-2019
    Vespasianus
    I am 6'1" and fit nicely on a XL Ripley. At 6'6", it would be very weird. I think I would need a 120mm stem!
  • 05-29-2019
    Alias530
    Figures below are Ripley/Following. Seat tube is the only place the Ripley is smaller and that's probably to accommodate longer droppers. Are there any other measurements I should be looking at?
    Seat tube - 482 / 508
    Top tube - 658 / 647
    Stack - 631 / 617
    Reach - 500 / 457
  • 05-31-2019
    DrPaulus
    You should be looking at a pole evolink 110 or 131.
  • 06-01-2019
    norbyd
    I'm in the same boat as the OP. I have a V1 Ibis Ripley and am considering getting a different 29er.
    An easy choice is the new V4 Ripley, however, I'm interested in researching other brands, there are countless these days: Whyte, Guerilla Gravity, Norco, Devinci, etc...
  • 06-02-2019
    rollinrob
    Intense Primer
  • 06-03-2019
    fmendes
    Rocky Mountain Instinct. I'm 6'4" and the stock XL felt too big for me (but I was riding a L before). I changed the stem from 50 to 40mm and moved the saddle forward the most I could so I could feel "at home". Stack at 630 made the seatpost be on the maximum insertion, and the min rear travel is 140mm. Checks all your boxes.
