Another Handlebar Question- Mtbr.com
Results 1 to 10 of 10
    SyT
    SyT is offline
    I've just acquired a bike that has the steerer tube cut shorter that what works with my normal bar of shoice (Salsa Cr. Mo. 17*) I'm looking for a bar with about .75-1" of rise but with at least 15* backsweep and NO up sweep. It would need to be in 31.8 so the Titec Jones is out. Any ideas???
    Masher
    Reputation: MisterC's Avatar
    isnt that what shims are for?
    Stand For Something.
    SyT
    SyT is offline
    Shims are for valve lash.
    I have other reasons for avoiding the Titec. Excess weight, have no use for the 'horns', to much rise at 1.5".
    Masher
    I'm out of ideas.
    SyT
    SyT is offline
    Me too. I realize it's a narrow focus situation.
    Former Bike Wrench
    Reputation: Nater's Avatar
    What about a higher rise stem and your beloved Salsa bars?
    SyT
    SyT is offline
    I run a 50mm stem. don't think I can get one with much rise. I went ahead and ordered the Carnegies, hoping that I can rotate them down enough to get them comfy yet still have some vertical gain. We''ll see. If they don't work, I have plenty of steerer on my rigid to use'em there.
    Map Maker
    Reputation: cbchess's Avatar
    +1 for the Ragley's I have two and they are GREAT. I just sold off my extra floWings. they would have worked too but you would have needed a shim.
    Nashbar has a medium sweep bar as well for super cheap.
    http://www.nashbar.com/bikes/Product...1_10000_200388
    its called the comfort handlebar because of the sweep. Its not half as cool as the Ragley
    but it is similar a bit more sweep at 30:
    31.8mm clamp, 720mm width, 23mm rise, 30 sweep.
    Richmond, VA
    Ra-MORE mtb club
    Former Bike Wrench
    Quote Originally Posted by cbchess
    The Nashbar Handlebar has zero forward sweep, requiring a John Holmes length stem to keep your hands in the right position. Otherwise it is a nice bar, I ordered one just because it was only $20 but I would need a 140mm stem to put my hands in the same location as my Space Bar OR with a 100mm stem.
