AARRGG this build is killing me. (brake question)- Mtbr.com
Results 1 to 12 of 12
    OK Im almost done building my canzo but the rotors dont fit. Marzocchi says the 44 fork will take up to an 8" rotor and the 185mm avid juicy rotor is about a half inch off. Should I get a 160mm rotor? Im at that bad at math? 185mm = 7.8"?
    (was) Big in Japan
    Reputation: TheSingleGuy's Avatar
    yes.
    1 inch = 25.4mm.
    Do you have (the correct) adapters?
    Ride.
    Just what came with the brakes. This is my first build so Im kinda new to it all.
    Reputation: c0nsumer's Avatar
    Post mount, right? Do you have the 185mm adapter for the caliper, which moves it out enough so that the rotor then fits? And did you fit the convex/concave washers too? If not, do both of those.
    The avid book says to remove adapter and install directly to the post
    Cannonball!
    Reputation: coiler-d's Avatar
    Sep 2004
    Typically the post mount caliper will work with a 160mm rotor with no adapter, on a fork with post mounts. For 185mm it will require an adapter, #00.5315.012.020, I believe.
    Quote Originally Posted by joshuab
    ...for 160mm. For 185mm rotors you need an adapter that moves the caliper outward along the posts. You can see one on my fork here. It's the (admittedly hard to see) bit between the caliper and the post with the arrow pointing up and the 185 POST marking.
    Former Bike Wrench
    Quote Originally Posted by coiler-d
    Correct, the Marz 44 has 6" Post Mounts, an adapter will be needed for the 185 rotor
    Reputation: Ronnie's Avatar
    What you need is one of these:
    http://www.chainreactioncycles.com/M...?ModelID=13717
    Attached Thumbnails Attached Thumbnails AARRGG this build is killing me. (brake question)-avid.jpg
    The trouble with having an open mind is that people will insist on trying to put things in it.
    Expert Crasher
    Reputation: GreenLightGo's Avatar
    Since this is your first build - make sure you use a torque wrench on the post mount - they are easy to strip.
    Happiness depends more on the inward disposition of mind than on outward circumstances. Benjamin Franklin
    Reputation: None's Avatar
    This has been the most helpful posts I have ever seen in the 29er forum!
    Thanks ordered one today!!
