30.9 to 27.2 Seatpost Spacer for Carbon 29'er?- Mtbr.com
Results 1 to 7 of 7
    Do they make a spacer for these sizes? I have a Tallboy carbon frame and I want to use my 27.2 carbon post, can I use a spacer for the 30.9 seatpost size? I think it's a 34.9mm seat collar size, if that helps. Is this advisable and if so where can I get a spacer?
    You know, for kids
    Reputation: madcap's Avatar
    search google shopping for "seatpost shim 30.9" and a plethora of choices will appear
    here's a nice one from Cane Creek...
    http://www.ride-this.com/index.php/c...ource=googleps
    as to whether or not shims are recommended for carbon, I have no clue but I wouldn't think it's ideal
    disclaimer: I sell and repair bicycles
    Former Bike Wrench
    I used a 30.9 to 27.2 spacer on a carbon post a few years back with zero issues (though in an aluminum frame). Recommend carbon friction paste for the shim/seatpost interface.
    I'll use the friction paste and check out the spacers!
    Nov 2006
    should not be a problem. used shims for various carbon applications.
    Sep 2004
    Should work no problem
    I use a shim on my roadbike, carbon frame and carbon seatpost. I would recommend a plastic shim like this one from USE
    http://www.pricepoint.com/detail/129...n-Seatpost.htm
    It is lighter than the aluminum ones and in my opinion, they seem less likely to cause any issues with the carbon.
    Definitely use the carbon paste.
    In FTF We Trust
    Reputation: el-cid's Avatar
    The only caveat I'll ad is check out minimum post insertion on the frame. The Carbon Cannondale Rush I had needed a minimum post insertion around 4". The shim will need to be at least as long as the minimum insertion depth.
    "I'll disintegrate over time if I expect my body to try to keep up with my mind" -BM
    Race, Rocks or Road...Just Ride
