29er tubes- Mtbr.com
Results 1 to 11 of 11
Thread: 29er tubes
    29er tubes
    Does anyone know where to get cheap 29er tubes?
    Sometimes you can buy 5 or 10 and get a discount.
    Student of the Bike
    Reputation: CBaron's Avatar
    I 2nd this motion.
    Big Wheel Homer !!
    Reputation: cruzthepug's Avatar
    Quote Originally Posted by EricJames
    Jenson has some for $2.50 each, about the cheapest I've seen.
    http://www.jensonusa.com/store/produ...alve+Tube.aspx
    Nat
    Nat is online now
    Reputation: Nat's Avatar
    You may know this already and have ruled it out, but just in case...you can use 26" tubes in 29er wheel. You just inflate it a bit first so it "grows" before inserting it.
    Shouldn't it always be inflated before inserting it...............?
    Save 15% off of your first Hammer Order
    http://www.tispindles.com/ - U.S. Made Titanium Spindles For Your MTB Pedals
    Nat
    Nat is online now
    Quote Originally Posted by ShoMyOFace
    In this case you inflate it a bit more than usual, so that it puffs way up.
    hispanic mechanic
    Reputation: sslos's Avatar
    Me, too...
    Quote Originally Posted by Nat
    I stopped using 29" tubes well over a year ago. There's more rubber than you need, and for some reason, they're ridiculously overpriced.
    Keep in mind, I live and ride in San Antonio, where we have lots of sharp-edged limestone and flint, not to mention cactus and 2" long mesquite thorns.
    Los
    Whiskey is my yoga.
    dongerparty.com
    Nat
    Nat is online now
    Quote Originally Posted by sslos
    Los
    Another benefit is that if you're on a group ride and someone with a 26" wheel needs the tube, he or she can use it, but I don't think it'd work very easily if you had the bigger tube.
    luckiest of the unlucky
    Reputation: JoelM's Avatar
    I'm just about over 26" tubes. Have you ever had to put a 26" tube in a 29" wheel during a race? It is beyond costly. I also had a 26" tube explode at high pressure the other day. I'd been riding it for two days, and I'm lucky I wasn't riding it when it blew, cause it blew the tire off the rim. I would have been hurt, bad.
    Reputation: tibiker325's Avatar
    Salsa cross tubes
    I got turned on to Salsa Cyclocross tubes (light version although I've never seen the "heavy" version) 700X44. They are around $4.50- $5.00 ( at LBS, but mail order may be cheaper) but they are almost half of the weight of 29er tubes, and lots of us use them with no pinch flats yet. You don't have to "pre inflate" them either.
    Recovering couch patato
    Reputation: Cloxxki's Avatar
    Such 45-45mm tubes have already exploded on me. You need to over-stretch them by quite a bit, and it seems to me that's more of a problem when it's about width than diameter.
    For racing, just obtain a couple high-end, low-weight 29" tubes, and only put them in your camelbak for that purpose. You still race on 26" Michelin Latex tubes, because those roll fastest and add grip. Not for 24hr solo though, they lose a tad bit of pressure overnight, being of porous latex.
