29er rim, w/ 28 holes, rim brake & tubeless???- Mtbr.com
    Kenatay
    I may end up eventially listing these in classified section but not giving up yet with trying to build up a set of wheels for a SS Karate Monkey. I got my hands on some beautiful Spot Brand SS hubs but found out after buy that front hub is 28 hole (rear is 32 - no prob) and there doesn't seem to be too many options out there for this front wheel build. The only one I can find to fit my wish is a Sun Ringle EQ21L and I'll be damned if I can locate a rim. Any suggestions before I offer them up to someone with 26" or road intentions?
    Bontrager used to make a Mustang rim with rim brake surfaces which could use the TLR rim strips, not sure if they did 28 hole though (I have a 32).
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Stans Alpha Road rims are the only ones I can think of that tick all those boxes.
    Reynolds MV36C rims are available in a 28h drilling. An easier solution may be just to run a disc up front?
    Yes - I do own Singular Cycles
