29er rim recommendations- Mtbr.com
Results 1 to 34 of 34
    I am looking for some rims to lace up to my King disk hubs. Any recommendations?
    Profound esoteric sentence encapsulating my philosophy and world view here.
    featherweight clydesdale
    Reputation: Fattirewilly's Avatar
    Dec 2001
    Quote Originally Posted by hardtail6
    Your weight, ride style, # of holes on said hubs, and desire yes/no to run Stan's/DIY tubeless would be profoundly helpful.
    rider specs
    weight: 175
    ride style: XC racing - single speed, probably no drops too big,
    hubs: 32 hole
    stans: sure
    Bored
    Reputation: bigwheelboy_490's Avatar
    Jan 2003
    MTBR is serious stuff.
    You never get better until you get out of your comfort zone.
    Reputation: sachase's Avatar
    Jan 2005
    My Salsa makes all the pretty girls take off their underpants.
    I ride Sun CR18 rims because thats what my bike shop had, but all of my 29er buddies love their salsa delgados, I've ordered a pair and Plan on building them within the next couple of weeks.
    Custom Independent Fabrications Ti Deluxe
    Carbon Niner Air 9 SS/rigid
    Carbon Niner Jet 9
    Ritchey Swiss Cross Disc
    Dec 2001
    weight: 175
    hubs: 32 hole
    stans: sure
    Skip the Velocity Dyads, the rim seems to be a hair to small to run Stan's with the currently available tires. The Mavic T-520, now called the 519 has held up well for me. If you want an off center pattern to reduce dish, check out Ritchy's Trekking rims or the Bontrager selections.
    Just Ride!
    Reputation: kustomz's Avatar
    I run Ritchey Rock Pro 700 and OCR Pro 700 with Stan's and Moto Raptors. They have never needed adjustment and the tires fit great for the tubless setup.
    Reputation: SoloWithOthers's Avatar
    Bontragers
    I would second the Bontragers as they should go nice with the King Hubs. They are known to be light and fairly strong. If you had Surly hubs I would say Salsa Delgatos for a cheaper and yet near bombproof wheelset.
    Get them built by someone that knows their stuff. Dave Thomas at SpeedDream would be my choice to match with the Kings and the Bontys.
    Mike
    Alex TD-17 ?
    What's the current verdict on the Alex TD-17 ? I'm currently looking for sub 600g, disk specific, wide (24MM+) rims for my 29".
    The Duuude, man...
    Reputation: ncj01's Avatar
    Quote Originally Posted by Fattirewilly
    I beleive you meant "now called the A719"....
    FS: Everything
    Dec 2001
    Quote Originally Posted by ncj01
    Yup, thanks!!
    Dec 2001
    Quote Originally Posted by kustomz
    How close are you to needing a tire lever with this setup?? What other tires have you tried on the Ritchey's and how tight were they??
    Your bike sucks
    Reputation: Carl Mega's Avatar
    I bought the mustangs. Nice looking rim. Read carefully: no tubeless rim strips for 29ers.
    I can't comment on their longevity because I just built them up and I haven't rode them on dirt yet. BTW- their ERD is closer to 603 rather than the 600 that was in the catalog.
    Just Ride!
    I would say it was an 85% hand job, but you definitely need a lever. The first set of tires on these rims were Mutanos, but they just fell on, so common since told me to run them with tubes. For the Motos (wire bead), and my recommendation to all Stan's users, is to take the extra 3 minutes and test fit the tire to the rim with no strip or tape! If the fit is loose, as in you can easily spin the tire on the rim, then you will most certainly need to calculate the amount of build up tape. I estimated that I needed two extra revolutions of reinforcement tape under the Stan's strip. In my experience, this has worked very well since last summer.
    On one occasion, I hopped from one ledge to the next but got the timing wrong and bottomed the tire to the rim with a hard kathunk (no rim damage). It burped a little air out, so I rode hard ahead of the pack to allow time to stop and put air in. In my haste, I pumped to violently with my Crank Brothers pump and yanked the stem from the strip, total loss of air. No big deal, in just a few minutes, I pulled the strip out and put a tube in and back down the trail I went. The next day, I simply removed the tube, glued the stem back into the Stan's strip pocket, re-assembled and all is well.
    Reputation: Bateman's Avatar
    Hey guys, I`m ver new to the 29er stuff and could use a recommendation for rims...
    I`ll want to use King SInglespeed Disc Hubs with 32holes and my riding style is normal MTB, no drops, nothing very had....
    I only ask because I have about 120 kilo and want rims to be strong enough...
    On my other bikes I ride DT 4.1 and Mavic X618 ...
    Thanks,
    Bateman
    jl
    jl is offline
    climb
    Reputation: jl's Avatar
    Rhyno Lites...
    We don't need more to be thankful for; we just need to be more thankful.
    Does anyone know a good online store where to buy 29er rims ???
    Here in germany nobody seems to have anything...
    Thanks,
    Bateman
    mtbr memeber
    Reputation: jpre's Avatar
    Quote Originally Posted by Bateman
    Speedgoat has quite a selection.
    http://www.speedgoat.com/catalog.asp?v=2&cat=260&dp=540
    Free shipping to US. Don't know about Germany.
    -John
    markybrue
    Jan 2005
    salsa delgado!
    I have built 12 wheels with salsa rims. I have never had any problems with them. the are quite fast but very strong!
    Jan 2005
    Did you happen to weigh those Ritchey's before you laced them up? I'm curious as to the actual weight. They are a claimed 470g front and 480g rear, which is the one of the lighter 29" specific rims I've seen (save for Stan's at ~400g and Bontrager at 460g claimed/490 actual). The Ritcheys look good at 23mm wide and with eyelets.
    Quote Originally Posted by gregk
    Are you guys talking about the 700c Trekking Rim listed on the bottom of this page: http://www.ritcheylogic.com/rims.htm?
    I was thinking about using these to build my wheels too. They don't appear to be named "Rock Pro" though. They seemed like a good option to me too.
    The Duuude, man...
    I just got 2 new Salsa Delgato's in from the LBS today to build up a couple front wheels...1 will be a REAL disc hub to go on the front of my new monkey, the other will be a gold non-disc King front as a spare......
    Let me say that I think the Salsa Delgato has the best of all worlds when your priorities are the combination of: Price, Strength, Weight, Durability, and Function.
    Let me also say that they look different that the older ones, must be the stickers on the rims, but they look dead sexy....
    FS: Everything
    Jan 2005
    Quote Originally Posted by Wish I Were Riding
    Yes, I was talking about the Trekking rim. The version with eyelets.
    bike-components.de
    Have look at: http://www.bike-components.de/catalo...?cPath=248_125
    The Mavic A719 and DTswiss TK 7.1 are both suitable 29er rims.
    The Duuude, man...
    Quote Originally Posted by skyblau
    Have look at the Mavic A719 and DTswiss TK 7.1 - both suitable 29er rims.
    Indeed. Retrospectively, I think they are on the same level as the Salsa's. The A719's are a tad heavier, a tad stronger, and a tad more expensive (by a factor of 2.3 or so). I built the A719's for my Leviathan where I wanted maximum long term durability, no matter the cost. But for most applications, I think the Salsa's where the smart money is.
    Related news: I corrected the rotor rub issue by going to a 6" rotor. Perhaps the 8" ones are thicker, i don't know...
    <img border=2 src="https://img.villagephotos.com/p/2004-10/867718/frontwheel.jpg">
    FS: Everything
    Sep 2004
    Sweet purple nurples. I'll give up brass for that kinda bling.
    Thanks guys, I had the Salsa Delgados in my hand a few hours ago...
    I maybe should have said that I want to use discs, and if there is any chance to find a rim which is disc only and without the sides for v-breaks I`ll try...
    or can I stop trying right now ???
    I just think that the look of V-Break sides on a rim used with discs is not that nice...
    Thanks,
    Bateman
    Recovering couch patato
    Reputation: Cloxxki's Avatar
    Bontrager Mustangs, Alex TD17's
    Klok - XC - Skate - Ski
    Thanks Cloxxki, now excuse my dumb questions and maybe you can tell me where to buy those and make my day a lot better...
    Thanks a lot,
    Bateman
    contains quinine
    Reputation: Debaser's Avatar
    This and other threads have been pretty interesting, as I'm building my first 9'er.
    I went with cr18's, building for disc use (no way I could use rim brakes on the non machined sidewalls!). They came together pretty well, and look better than I imagined. They were also darned cheap, and I picked them up locally.
    Now I'll hope they hold up!
    Take the long cut, we'll get there eventually.
    Sure thing. Bontrager at any Trek/Fisher/Klein dealership.
    Alex, hmmm...I must admit I got mine when I worked at an LBS with a distributor in the USA. It's a world-wide operation though, right?
    What bike are you planning to build up?
    I left out my personal favorite (which I never got to use, because it was disc-only). Rigida Taurus2000. It's 26-27mm wide, it's black disc only, and 520g. A good LBS will know where to ask for them. Rigida uses regional distributors I believe, that also supply shops with everything for citybikes. The Taurus would add a bit of volume to the tire, which is good. High-end trekking bike specialists might know some more as well.
    Good luck!
    Thanks for the quick answers Cloxxki...
    It is gonna be a Sycip 29er, Singlespeed, what else
    Unfortunately the LBSs here are very very unwilling to help...
    You can buy complete bikes there, but if you need anything which only smells special first thing you hear is "we don`t know, we never had that and can`t order it or it doesn`t exist "...
    But I guess I`ll find that somewhere, and then I`ll post the bike when its ready...
    Right now the frame needs some colour and then must be shipped to me...
    Bateman
    The Duuude, man...
    I know what you mean....for my personal tastes, I like a V-rim on a Disc hub...maxiumum versatility is king for me...
    If i wanted a disc specific 29er rim, it would be the bontrager Mustang, alone without a competitor...
    FS: Everything
    highly visible
    Reputation: GlowBoy's Avatar
    Never gotten a chance to weigh the rim, but the rear wheel on my 'crosser the last 2 years has been a Rock Pro OCR, and it's held up great. I'm also happy with the 3 Delgados that I have, too. Never weighed those either, but rumor has it that their weight varies a LOT, and can end up in the neighborhood of 80-100g more than claimed.
  1. 29er rim for a Clyde
    By Winky in forum 29er Bikes
    Last Post: 02-12-2005, 08:27 PM
  2. any rim recommendations?
    By NoSkillz99 in forum Trek
    Last Post: 11-09-2004, 05:52 AM
  3. 29er Wheel flex, rim brakes vs disk brakes
    By Kansasflatlander in forum 29er Bikes
    Last Post: 10-05-2004, 08:31 PM
  4. Rim Trail recommendations please!
    By Appendage in forum California - Norcal
    Last Post: 07-19-2004, 09:33 AM
  5. Replies: 9
    Last Post: 05-12-2004, 05:19 AM
