29er forks more likely to snap than 26 inch forks?- Mtbr.com
Results 1 to 14 of 14
    Alastair78
    Guest
    I am looking at bikes with Fox 26 inch and 29 inch forks. Both seem identical & both have 32mm stanchions. It seems to me however, that having a 29 inch fork would put more leverage on the usual snapping point (just below the crown).
    Any thoughts on this? The only thing I can think of is that perhaps the 29er forks have thicker walls.... but somehow I doubt it.
    Reputation: thickfog's Avatar
    Oct 2010
    Why do you feel you would snap either?
    There are far more delicate parts of a bike to worry about.
    Alastair78
    Guest
    Quote Originally Posted by thickfog View Post
    I am 100kg (220 pounds). Also I have seen a few snapped forks in the same place, inlcuding fox (older ones though)... Still a chance when the rider weighs more.
    it depends on how you use the bike,if fork snapage is a concern of your's (you know how you ride) then maybe the 29er thing is not for you,If you land hard enough to possibly snap forks the 29 inch wheels are not gonna be happy either.I stayed with 26 inch wheels because of this.
    ballbuster
    Reputation: pimpbot's Avatar
    I haven't seen an snapped fork in 9 years, except for some cheap chinese made titanium rigid forks that broke at the faulty welds from the legs to the crown. Titanium takes some real skill to weld correctly, and I guess the mfg didn't get it hot enough.
    I don't think it's a real concern, as long as you're using a fork within its designed use limits... that, is, you aren't doing 20 foot drops to flat on an XC fork, or land splayed on the top of a jump, pulling the wheels apart.
    Plus, when suspension forks break, they usually break at the steerer tube, right at the crown race. I think you are more likely to crack off your head tube under that much stress.
    BTW, I'm 215 (was 220) and have been mostly riding Rebas (light-ish XC forks) for the last 7 years.... until I got a Lefty!
    <a href="https://picasaweb.google.com/lh/photo/yTF1CC17qrHKo033GcQd6w?feat=embedwebsite"><img src="https://lh3.googleusercontent.com/-cu86giT6nrc/Tc8qQBCDC-I/AAAAAAAAUAg/OX9yl0zdbz8/s800/IMG_0518.JPG" height="800" width="600" /></a>
    Race 29ers have a straiter rake on the fork for faster steering and it causes less drag on the steering. Check it out.
    Spinnin' & Grinnin'
    ballbuster
    Huh?
    Quote Originally Posted by Rad Rider 415 View Post
    Less rake is slower steering. More rake makes it feel faster. The trend in 29er frames has been toward slightly slacker head tubes but with more rake to keep the bike feeling 'quick'. This eliminates toe overlap. Old rebas have 38mm offset, and newer ones are 45mm. Lefty is 45mm also.
    All forks have to pass the CEN test now and the frame and fork tests are rigourous.
    The test is harder to pass for longer forks due to the leverage. You can be sure Fox test as stringently as anybody and if both forks pass, then they've done their sums on wall thicknesses and crown joins to be sure you can be confident in either fork. Nothing is unbreakable but if you're riding 'normally', don't worry about it. As said above, wheel strength may be more of a concern but a good builder will account for that, no problems there.
    Missouri sucks...
    My 6'6", 250lb best friend has been riding a Dart3 *HARD* for almost 3 years now. That's the perfect storm for catastrophic fork failure. Nothin...
    Alastair78
    Guest
    Quote Originally Posted by DFYFZX View Post
    I have been riding a Dart 2 for 2+ years (HARD), and its still going strong. Just shows that there is hardly any strength difference between the forks. In fact some of the cheaper ones may even be stronger as they have steel components.
    ballbuster
    Yeah, I think the main point is, the engineers and designers know that a longer fork is going to have greater forces on it than a 26er fork, so they make them beefier to take it.
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    Quote Originally Posted by Alastair78 View Post
    That's kind of hard to quantify that there is hardly any strength difference. I think it would be safer to say that forks are generally strong enough for the use they were designed for. At any rate, although there are a lot more riders that weigh less than you, there are plenty that are larger and likely ride harder. If you haven't 'snapped' your 26" Dart, I think you'll be fine with 29er forks. May be time for you to ride something that is a step up from a Dart though if you can afford it.
    Oct 2010
    bike tester
    Reputation: syl3's Avatar
    OMG, a road fork snapped when jumped, THE SKY IS FALLING!!!1!
    <iframe width="560" height="349" src="http://www.youtube.com/embed/5z1fSpZNXhU" frameborder="0" allowfullscreen></iframe>
    Oh, this one didn't, nevermind then
  1. 1 inch 29er forks?
    By 1971tch in forum 27.5
    Last Post: 11-05-2011, 02:36 AM
  2. Replies: 5
    Last Post: 01-14-2009, 11:16 PM
  3. 6 inch forks
    By yespsb in forum Shocks and Suspension
    Last Post: 10-15-2005, 05:02 PM
  4. 6 inch forks
    By StoneFox in forum Downhill - Freeride
    Last Post: 04-27-2005, 08:23 PM
  5. Anyone run or seen 8 inch rotors on Fox Forks?
    By dwurfel in forum Riding Passion
    Last Post: 06-21-2004, 10:44 AM
