29" Fuel EX or 29" Short Travel Stumpy?- Mtbr.com
Results 1 to 10 of 10
    Feb 2017
    I ride tight twisty rooty (!) singletrack with lots of short ups and down (like 5-10' maybe as I'm in Houston). No more than 2-3' drops and like to keep wheels on the ground (too old). No marathon climbs and definitely no long cruising downhill sections.
    Coming off an old 4" front and rear travel 26" wheeled bike. If you were to pick one based on trail description which would you think is better? I seem to think ST STUMP is more suited for tight singletrack.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by MaxMyNameisMax View Post
    Fuel, for a lot of short accelerating climbs, the Stumpjumper is going to be more lethargic and mushy. If the climbs were longer the stumpjumper might be ok to put your shock on the "climb" setting and deal with the extra harshness, but the Fuel has a flatter anti-squat curve and should keep the front end down and pedal more consistently as your weight shifts, you weigh less or more, the suspension cycles, etc., without having to use a climb-lever thing.
    The fuel does have 10mm more travel, that's probably a bit much and 115-120 is probably your sweet spot for that terrain. I felt 100mm was ok in Dallas/SA/Austin but in a couple spots I wanted just a bit more.
    I'd look at Devinci, Ibis, Pivot, SC and Yeti. All have solid offerings in that range that will pedal better than the Specialized and keep the front end down.
    Feb 2017
    I would love to try an xxl Tallboy (Iím 6í4Ē) but impossible to find in stock.
    Reputation: wideawakejake's Avatar
    Jan 2015
    I have the new SJ ST in 29er flavor. It is anything but mushy and lethargic. It would be a really good bike for your type of riding and trails. I am in my 40's, been riding along time and had lots of bikes. Trust me, they did a good job with this one. Its a fast bike. Climbs great, drops great. Rides fast and smooth. I am 220lbs loaded up and can tell you that the short travel version SJ has plenty of travel for its purpose. You cant really go wrong with any of the modern bikes out there. The bike before this was a Tallboy +. That bike was a dam good bike, but I like the new SJ more. Before the Tallboy, a Trek Fuel for short time. I hated that bike. Just did not gel with me. But my buddy ****ing kills it on his Fuel and loves his. You can throw all the geo and technical suspension curve charts out there all you want, none of it matters like how the bike performs while you are riding it.
    Jan 2015
    "Jayem"...i did not mean to come off as a douche. I should have portrayed our different opinions on the same bikes more light hearted. my bad
    Reputation: targnik's Avatar
    Jan 2014
    Pivot Trail 429 ;-)
    'Born to ride!'
    "Mountain biking: the under-rated and drug-free antidepressant"
    Quote Originally Posted by targnik View Post
    Pivot Trail 429 ;-)
    'Born to ride!'
    The hub size is a big drawback on that one for me. Great bike, but I have absolutely no interest in super-boost.
    I'm waiting for super-duper-boost.
    Jan 2016
    I have ridden both and you should also----for me the Stumpy climbed sluggishly and both were similar downhill----my daily driver is a Pivot 429T so that is what I compare to---I wanted to love the Stumpy but if just felt sluggish in comparison. Everyone will have an opinion and other options and those who own a bike seem to have trouble being critical so in the end you must ride them yourself
    No Clue Crew
    Apr 2005
    Iíve owned both (though the regular version of the Stumpy, not the ST). Which do I still own? The Stumpjumper.
    Jayem likes to trot out tired cliches about bikes heís likely never ridden.
    I wanted to like the Trek, but it just didnít do it for me.
    All that said, the older Pivot Mach 429 Trail is an excellent bike for the trails you describe. And you can find them on closeout. Only issue is the odd sizing. I owned an XL at 6í2, 34 inseam, +2 ape index. The geo is a little old-school, but still a rad bike.
    Just like a raindrop, I was born to fall.
  1. A Different "Which Bike" Thread; 4" Travel vs 5" Travel
    By xray_ed in forum Endurance XC Racing
    Last Post: 01-17-2016, 06:18 PM
  2. Short travel 29er or mid travel 27.5?
    By bikerfisher11 in forum 29er Bikes
    Last Post: 10-29-2015, 09:48 AM
  3. Replies: 6
    Last Post: 05-27-2015, 11:01 AM
  4. short travel, slack, short chainstay FS
    By r1Gel in forum 29er Bikes
    Last Post: 07-24-2013, 08:33 PM
  5. Long travel or short travel?
    By Loll in forum 29er Bikes
    Last Post: 08-09-2011, 01:44 PM
