2014 Stumpjumper EVO HT vs. Santa Cruz Highball R XC build...Which to buy??- Mtbr.com
Poll: stumpy evo ht OR highball R XC ????
Be advised that this is a public poll: other users can see the choice(s) you selected.
Results 1 to 9 of 9
    Jan 2014
    So here is my dilemma....
    I got two questions?? Please and thank-you
    2014 Stumpjumper EVO HT vs. Santa Cruz Highball R XC build...Which to buy??? They are both @ 2200$
    Should I be concerned with the drive train 1X10 vs. 3X10??
    The build for the Highball is :
    Highball Aluminum R XC 29
    32 Float CTD 100 fox shock
    Drivetrain
    Front Dérailleur Shimano (Deore)
    Rear Dérailleur Shimano (SLX)
    Shifters Shimano (SLX)
    Crankset Shimano (Deore) 24/32/42
    Bottom Bracket Included w/ crankset
    Cassette Shimano HG 81, 11-36 (SLX) 10spd
    Chain Shimano HG 75 10spd
    Brakes
    Brakes Shimano M615 (Deore) w/ 160mm rotors
    Steering
    Headset Cane Creek 10
    Bars Raceface RIde Flat Bar 710mm
    Stem Raceface Ride 70mm or 80mm
    Grips Lizard Skin "494"
    Wheelset
    Front Hub SRAM MTH 716
    Rear Hub SRAM MTH 746 or Shimano M756 (XT)
    Rims WTB ST i19 TCS
    Spokes DT 14 gauge spokes, brass nipples
    Tires Maxxis Ikon 2.2" Tubeless Ready Kevlar
    Tubes Tubeless (Stans Sealant)
    Seating
    Seat Post Raceface Ride
    Saddle WTB Volt Race
    Stumpie Evo HT
    FRAME
    M5 fully manipulated alloy, 29" geometry, tapered headtube, PF30 BB, PM 140mm rear brake, 135mm dropouts, replaceable derailleur hanger
    FORK
    FOX Float CTD Evolution 29, air spring, tapered steerer, Climb, Trail, Descend settings and reb adj., 15mm thru-axle, 15.5": 80mm, Others: 100mm travel
    HEADSET
    1-1/8 and 1-1/2" threadless, Campy style upper with 1-1/2" lower, cartridge bearings
    STEM
    Specialized XC, 3D forged alloy, 4-bolt, 6-degree rise, 31.8mm clamp
    HANDLEBARS
    Specialized XC Mini-Riser, 7050 butted alloy, 720mm wide, 10mm rise, 8-degree backsweep, 6-degree upsweep, 31.8mm
    GRIPS
    Specialized Sip Grip, light lock-on, half-waffle aramid-infused, 15.5"/17.5: regular, 19"/21": XL thickness
    FRONT BRAKE
    Formula C1, alloy caliper, metallic pad, S/M: 160mm, L/XL: 180mm rotor
    REAR BRAKE
    Formula C1, alloy caliper, metallic pad, 160mm rotor
    BRAKE LEVERS
    Formula C1, hydraulic disc, tooled reach adj.
    REAR DERAILLEUR
    SRAM X0 Type 2, 10-speed, mid cage
    SHIFT LEVERS
    SRAM X7, 10-speed, w/ MatchMaker clamp
    CASSETTE
    SRAM PG-1030, 10-speed, 11-36
    CHAIN
    SRAM PC 1031, 10-speed, PowerLink
    CRANKSET
    Custom SRAM S-1250, 7050 alloy arms, 33T XX1 style single ring, PF30 spindle, 15.5": 170mm, Others: 175mm
    BOTTOM BRACKET
    SRAM PF30, OS press-in bearings, sealed cartridge
    RIMS
    Roval 29, alloy disc, 28mm wide, 32h
    FRONT HUB
    Specialized Hi Lo disc, sealed cartridge bearings, 15mm thru-axle, 32h
    REAR HUB
    Specialized Hi Lo disc, double-sealed cartridge bearings, QR, 32h
    SPOKES
    DT Industry Stainless, 3X front/rear 2.0
    FRONT TIRE
    S-Works Purgatory, 2Bliss Ready, 29x2.3", foldable aramid bead, dual-compound, 120 TPI
    REAR TIRE
    Specialized Ground Control, 2Bliss Ready, 29x2.1", foldable aramid bead, 60 TPI
    SADDLE
    Body Geometry Phenom Comp, hollow Cr-Mo rails, 143mm
    SEATPOST
    Specialized 2014 butted alloy, single bolt setback, 27.2mm, 15.5/17.5" 350mm, Others: 400mm
    SEAT BINDER
    Specialized 7050 hard anodized alloy, single bolt, 31.8mm
    I don't consider this price range to be good value for a ht when you are getting an aluminum frame as part of the mix. The lack of compliance of aluminum is a significant handling characteristic. You get all that with a $1k- $1.5K bike. Carbon frames can be compliant or fully stiff. But a carbon frame engineered for compliance is a different class of bike then any aluminum bike. If you work a discount a Superfly 9.6 is close to or under $2k. The compliance and resulting fun hitting rocks going downhill puts it more than a ht with trail feel you lose with a fs. The fork will benefit from a damper upgrade to SID Motion Control DNA RLT(170 list) This is a new frame with new geo, not carry over.
    29ers Forever
    Reputation: CannondaleF9's Avatar
    Nov 2012
    How about the Trek Superfly 9.6 or Scott Scale 930?
    Dropping into a trail
    2019 Rocky Mountain Instinct A50 BC
    2019 Salsa Timberjack SLX
    2014 Trek Crossrip Elite
    Quote Originally Posted by CannondaleF9 View Post
    Scott has more limited tire clearance between the chainstays, 68.5mm unless it has been changed for 14. The Superfly has close to 80mm. Trek is using their road bike carbon engineering team on this frame. You can feel the benefit of those guys being involved.
    Reputation: redmr2_man's Avatar
    i voted highball, but for the money you're paying new for a lower end build, you could have a year old baller-rig for less.
    Not trying to steer you either way, just don't forget the used option. Both of those bikes are awesome, I just like the highball a little more.
    Jan 2013
    Quote Originally Posted by redmr2_man View Post
    Same here, highball looks like the best option for you but you really can't got wrong with stumpy either. I would also take a look at the used market if I were you. There some pretty good deals every now and then.
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    Since I ride a Highball.....that is my choice.
    Been on it for the last year. Have only run it as a singlespeed...but like the idea that I can put gears on it if I choose to do so.
    Bicycles don’t have motors or batteries.:nono:
    Ebikes are not bicycles :nono:
    Jan 2014
    Oct 2011
    I voted HB only because I own one with more than 1500 miles on it. And it has treated me very good.
    The other bike in the poll I know nothing about.
  1. Santa Cruz Highball SS Build
    By bmschrad in forum Singlespeed
    Last Post: 01-16-2015, 04:41 PM
  2. Sub $2k Santa Cruz Highball build
    By mmm...bicycles in forum 29er Bikes
    Last Post: 08-30-2013, 10:24 AM
  3. Replies: 12
    Last Post: 04-17-2012, 04:49 PM
  4. Santa Cruz Highball
    By cannonballtrail in forum 29er Bikes
    Last Post: 11-05-2011, 08:14 PM
  5. Santa Cruz Highball
    By LandSpeed in forum 29er Bikes
    Last Post: 08-16-2011, 01:45 PM
