2014 Salsa Split Pivot Spearfish/Horsethief (Details)- Mtbr.com
Results 1 to 18 of 18
    May 2010
    Reputation: bikewrench's Avatar
    Nov 2006
    Glad to see that they revised the cable routing. That was my only true complaint w/my 'fish.
    I turn a wrench @ Simplicity Cycles
    http://www.simplicity-cycles.com
    Rohloff
    Reputation: bsdc's Avatar
    I'd like to see them with an X01 build.
    Lackey
    Reputation: Joshua Pattersnap's Avatar
    Quote Originally Posted by bsdc View Post
    The Horsethief 1 will be equipped with X01.
    The only Spearfish to rock 1x11 is the top-of-the-line XX1 build.
    Reputation: Epic_Dude's Avatar
    May 2010
    I like the Spearfish in the XX1 config and the new cable routing looks much better.
    Rohloff
    Quote Originally Posted by Joshua Pattersnap View Post
    Thanks. I see that now. XO1 is 1x11 as well.
    Nov 2007
    Old Horsetheif single pivot. New horsetheif split pivot.
    They are likely completely different bikes, why keep the name?
    meow meow
    Reputation: b-kul's Avatar
    ^why not? many companies change up bikes but keep the same names. turner, gt, trek, etc.
    Reputation: progfan1's Avatar
    Great, now I'm probably gonna want to sell my 2012 'Thief!
    2012 Salsa Horsethief
    2005 Independent Fabrication Deluxe
    Rohloff
    What's the deal with "split pivot"? To me it looks like Trek's single pivot with ABP. Am I missing something?
    They're close to the same thing. I think DW sued Trek over it in 2007, but I'm not sure who won that one.
    Edit: Seems like it's still going on: Trek says Weagle's patents invalid; trial date set | Bicycle Retailer and Industry News
    beater
    Reputation: evasive's Avatar
    Feb 2005
    I've ridden a couple Split Pivot bikes (Devinci Atlas and Dixon) and I liked the feel. Good move from Salsa, IMO.
    Reputation: Ronnie's Avatar
    I'm posting to subscribe to the thread. I'm considering a full suspension trail bike and the new Horsethief interests me. I tried to find some geometry information but there is none. Does anyone have any idea of chain stay length and head angle?
    Also, the press release quotes:
    "Geometry control: Split Pivot's optimized wheel link placement results in anti-squat properties that allow the bike to ride higher under powered acceleration."
    I've owned bikes with for example VPP which has anti-squat designed in. This is still a single pivot design and would like to understand what it's "anti-squat properties" are.
    The trouble with having an open mind is that people will insist on trying to put things in it.
    Aug 2010
    That flex stay made out of aluminum always looked sketchy... This looks much better.
    Reputation: Ottoreni's Avatar
    Even uses a 51mm offset fork like Trek.
    You cannot go against nature, because when you do, its part of nature too.
    May 2013
    I wonder if the rear triangle can be retrofitted to my 2011 spearfish.
    Salsa Cycles Spearfish And Horsethief ? First Look - BikeRadar
    17.2" stays with half degree slacker angles on both models. New Horsethief sounds like a ripper!
    I'm very interested in these bikes. Probably the Spearfish, since its still a LOT more travel than I usually ride. But can someone explain to me why these bikes use the BB92? What does it get me? I do NOT want to be chasing squeaky BB issues, ever.
  1. Replies: 9
    Last Post: 11-04-2013, 05:54 AM
  2. 2014 Salsa Split Pivot
    By Pancake Adventure in forum Salsa
    Last Post: 06-29-2013, 07:50 AM
  3. 2012 Salsa Horsethief vs 2013 Salsa Horsethief 2
    By Radioface in forum 29er Bikes
    Last Post: 01-09-2013, 03:33 AM
  4. Pivot Mach 429 or Salsa Horsethief
    By EGF168 in forum 29er Bikes
    Last Post: 03-31-2012, 05:50 AM
  5. Replies: 0
    Last Post: 03-18-2012, 04:08 PM
