1x9 Setup Advantages- Mtbr.com
Results 1 to 31 of 31
    I'm on 1x9, done by removing front gear and taking off big ring and granny ring from a XT crankset. I have a device to keep the chain in place, and I replaced the rear derailleur with a short cage version when it brok recently, but otherwise it was a simple move over.
    Is there any other kit that would improve my 1x9, specific cranks etc ?
    pedal pusher
    Reputation: f3rg's Avatar
    No, sounds like you pretty much have it right.
    Personally, I like to use a bashguard to protect the remaining chainring and keep the chain from falling off on the crank side, but that's up to you.
    Squishy Fishy
    Nov 2008
    I used two salsa ringdingers on either side of the xt ring. Worked great until I kept missing my big ring, so I ended up back to where I started. Without the granny, though.
    Quote Originally Posted by cagey76
    I run 1x9 with a short cage XT and it works very well. I'm wondering if a non-ramped SS ring would make the set-up a bit quieter?
    If you're already using a BG and jumpstop, does an SS ring offer any benefits? I'm thinking it will make my chain track perfectly onto the ring and eliminate any noise of the chain riding onto the ramped teeth
    Designated Bleeder
    Reputation: SpecialK's Avatar
    Feb 2005
    Non ramped ring
    I run a 1x9 setup on my Niner EMD and had a lot of trouble with the chain dropping until I got a single speed specific non-ramped chainring. If your chainline is not quite right with a ramped ring, the chain will fall off periodically. If you don't mind that, its no big deal but my chain always seemed to fall off at the most inopportune times.
    I run a single speed ring up front (a Blackspire) with a bash guard and a jump stop on the inside. I have never had my chain fall off with the setup, regardless of the length derailleur I have used. Honestly, I probably don't even need the bash guard but I prefer not to lose teeth on my chainring.
    Good luck. 1x9 is the way to go on a 29er. A little easier to climb than a singlespeed but without the hassle of a lousy front derailleur...
    offroader
    Dec 2008
    Non Ramped chain ring
    Bash guard
    jump stop
    short cage RD
    shorten your chain
    as others have mentioned...
    I would also consider going to a 34T up front instead of 32T.
    Quote Originally Posted by SpecialK
    I run a 1x9 setup on my Niner EMD and had a lot of trouble with the chain dropping until I got a single speed specific non-ramped chainring. .
    Huh, I also have an EMD and have never dropped a chain using the Ngear jumpstop. I would actually like to drop the bashguard and just use a non-ramped ring for a much cleaner look..I don't know how that will play out though
    Reputation: Vecsus's Avatar
    the number of teeth on the chainring is largely dependant on the type/location of the riding you do. I normally run a 32T but for the SM100 this weekend I will be using a 30T because I want to make sure I have the gearing for late in the day, not just when my legs are fresh.
    Vecsus
    HTFU or STFU
    Reputation: newking's Avatar
    Nov 2007
    I run a 32t front ring,11-34 cog, med cage xo rd, jump stop to keep the chain on and bash guard for rolling over logs. My chain never comes off & there are zero shifting issues..1x9 pretty much covers everything from flats to super steep hills with low maintainence, low weight less bar clutter. Would never go back to 3x9.
    Apr 2005
    i am running a 1 X 6 with 11-32 rear cogset and a 32T Salsa single speed chainring, and a medium cage sram x9. the chain has never come off the front ring, and so i haven't bothered to buy an n-gear jumpspot...it ain't needed.
    i have the chain length at big/big+2 links, and have a healthy amount of b-tension but nothing excessive.
    Originally posted by bucksaw87
    I still fail to see how mustaches, fixies, and PBR are ironic.
    Reputation: bigfoot_mt's Avatar
    You can also grind the teeth of an old big ring and have a ghetto bashguard. it actually tuns out pretty cool.
    Reputation: bycyclist's Avatar
    Quote Originally Posted by newking
    Amen! I've had no issues climbing the stuff around Tahoe like I was afraid of.
    Running XTR med rear, 11-34 cassette, using 32T Blackspire chainring. Held in place with MRP 1.X.
    Dec 2008
    Is it possible to use a short cage road (ultegra for example) with a 11-32 cassette?
    I live in the Netherlands and it's completely flat here so I might also try a 12-27 cassette, but I would like the wider range in combination with the a very short cage!
    I am thinking about going to a 1x9 setup but have a few questions I hope someone can answer.
    First, I have a Paragon that comes with a 11-34 cassette and a 32T chainring that I would use. Can I run a shortcage derailluer? My shop has an X-0 in stock and would like to get it.
    Next, anyone run the X-0 gripshifters? I have X-9 triggers now but would like to try it. What are you opinions on it?
    29" Trail Assault.
    i run an X-0 short cage RD and it works great. Can't weigh in on the shifters though....i use the X-9 triggers.
    Vecsus
    HTFU or STFU
    Having a nice day!
    Reputation: LoneStar's Avatar
    BTW, the MRP 1.x works great for a 1x9.
    Reputation: Soupboy's Avatar
    Quote Originally Posted by LoneStar
    It does indeed.
    Professional Amateur
    Nov 2008
    I'm on 1x9, .... is there any other kit that would improve my 1x9, specific cranks etc ?
    I run a Stylo 1.1 crank w/ x-9 med cage RD. No problems here in TN. I am able to climb almost anything I want. Still keep a 26" 3x9 for other riding though, but the 29er is becoming my favorite bike. Have fun and ride often.
    GapRider MTB
    aka Chuck Faulkner
    Tazewell TN 37879
    http://www.jeffrothcyclingfoundation.org
    I use a DMR version, chain has never come off !
    http://www.dmrbikes.com/Section=prod...s&itemid=CDCC2
    cheers for the responses.
    Basura Blanca
    An Ultegra short cage is exactly what I've got my wife running on her Bandersnatch 1x9, and it works fine.
    - Joe
    Quote Originally Posted by partyboj
    We rejoice in our suffering, knowing that suffering produces endurance, and endurance produces character.
    Dec 2005
    For the 2x9 or 1x9 are there lightweight bolts for it or do you guys use hardware store found bolts and washers?
    I'm just messing with you
    Reputation: wv_bob's Avatar
    After two rides on my new 1x9 29er, I'm climbing everything I climbed on my 3x9 26er, and more. It's like riding SS, momentum is your friend.
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    I just bought new crank bolts at my local cycle shop for $8. They come in different sizes.
    Reputation: cruso414's Avatar
    if you think 1X9 is cool, try 1X1.;>)
    Quote Originally Posted by bjwam
    Ask for BMX bolts.
    "Bikes aren't fast--people are fast. Bikes are overpriced. It's an important distinction."---BikeSnob NYC
    bt
    bt is offline
    Nov 2007
    anyone ever try 3x9?
    Reputation: onlycrimson's Avatar
    Nov 2008
    Quote Originally Posted by bt
    lol. I'm going to say yes.
    cruso, when my 2010 bandersnatch arrives, my current niner frame is going to become the start of my first 1x1 project, should be a laugh.
    Mtbr
    Reputation: dbo43867's Avatar
    Quote Originally Posted by MtnBikeNC
    Non ramped ring IMO is not quieter but it holds the chain MUCH better. On my 1x9 setup I don't even need a bashguard with the non ramped, whereas I used to with a ramped ring.
    2008 Rig
    Quote Originally Posted by wv_bob
    I knew you'd come around eventually. Congrats on the new 29er.
    Reputation: jadedbee's Avatar
    My only complaint...
    I have been singing the praises of 1x9 for a year and a half, commonly telling people it has had zero cons for me. Recently, tho, I realized a potential drawback: rear tires! I have found it absolutely necessary to get the grippiest (read: heaviest) rear tires I can and to replace them as soon as the tread begins to loose it's bite. There are steep hills around here (Folsom/Auburn) that I can clean fine with the 1x9 gear, but once the rear tire begins to fade, no amount of finesse can keep it from slipping when you're torquing an 11:34. A recent trip to Tahoe highlighted this fact. Put on a new AM tire and it's like I've got an extra gear. So, the minimal weight you're saving in the drive train is going into meatier tires, and you're spending more on them (wear the tread quicker, can't wear it down as short before replacing, and have to buy more expensive replacements).
    I still haven't used a front derailleur I liked, though, so I will be sticking with this setup. I hate having to think about shifting, but harder=button1, easier=button2 is instinctual. "Should I go 5 down in the back or 2 forward and 1 up in the front?" is not.
    Plus, rotational weight can be your friend, as any SSer will tell you, 'cause it preserves momentum. And bigger rear tires take even more sting out of my HT, along with the steel frame and wagon wheels.
    Rollin' rocks will never die...
