142x12 Hardtail Frame Options- Mtbr.com
Results 1 to 23 of 23
    Jun 2014
    I have a set of spank oozy 350 wheels in 142x12, Eagle GX drivetrain, Pike fork, and a few leftover parts that I'd like to use to build up a fun geared hardtail. Currently have this setup on my Nimble 9, but I've been missing that bike in it's SS form. A rigid carbon fork and i9/Atomik wheelset would go back on the N9.
    Wanting to spend $750 or less, and my first thought was SC Chameleon. Go to the bike shop and am told that they no longer make 142 geared dropouts for the Chameleon.
    Geo numbers I'm looking for
    HA: 66-67 w/ 120-140 fork
    CS: 420ish
    STA: 74ish (no extended climbs in florida, so no need for stee sta)
    ST Length: 460 or less. this is very important because I have short legs
    Reach: 450-460
    Not too worried about material or weight. Fun factor is all I really want. Love my N9, but miss it in SS. Stanton makes beautiful bikes with swappable dropouts, but shipping to US blows the budget on this bike.
    Get a chromag rootdown or primer, I知 loving this frame so far...though I知 running a bit more travel
    Jun 2014
    Quote Originally Posted by cachaulo View Post
    Lovely frames, but they are boost 148
    Looked at Surly? I have no idea on the measurements but the rear end can be run 142 or 148. Krampus or such might fit the bill.
    Quote Originally Posted by GatorXman View Post
    Sorry, past models are 142...at your price you could certainly find a used one.
    https://chromagbikes.com/bikes/past-models/rootdown
    Reputation: the_joe's Avatar
    Feb 2017
    Salsa timberjack... 142 compatible with the right dropout plates, singlespeed ready
    Also some Surlys
    My name is George. I知 unemployed and I live with my parents.
    2017 BMC Speedfox 25-622 ISO
    2017 Salsa Timberjack 40-584 ISO
    KVV
    KVV is offline
    May 2017
    Pole Taival maybe? I've heard they started to ship.
    Reputation: David R's Avatar
    Buy some adaptors and take your pick from more modern frames?
    Jan 2009
    Yeah, boost adapters work fine from what I hear. Some people glue or shrink-wrap the adapters to the axle to avoid dropping and losing them.
    A medium Honzo might do it. The Surly Karate Monkey has a much shorter reach.
    Jun 2014
    Quote Originally Posted by the_joe View Post
    Also some Surlys
    Quote Originally Posted by leeboh View Post
    Timberjack is too steep. Love the Karate Monkey, but M is too short on reach, L is too long on seat tube. I have a +2" Ape index with shorter inseam. The one thing I hate about my L N9 is that I can only fit a 75mm dropper on it.
    Quote Originally Posted by David R View Post
    Quote Originally Posted by mack_turtle View Post
    Have people had success running adapted on short CS bikes? This would be ideal if a chain line issue isn't created. Medium Honzo has EXACTLY what I am looking for...
    Jan 2009
    I don't see what adapters have to do with the short chainstays. For the chainline, you might need to move your chainring around a bit to center it, depending on the rest of the setup.
    Jun 2014
    If you a get a single 6mm spacer, you have to redish wheelset. If you get two 3mm spacers, your chainline moves 3mm. I prefer not having to redish, and as I understand short chainstays magnify chainline issues.
    Eskar Hayduke can be had in 142.
    powered by peanut butter.
    Reputation: heartland's Avatar
    I'm using a Wolftooth Boostinator in the rear on a frame w/ chainstays just under 17''. Works great, no issues. With my DT350 hub, the Boostinator endcaps fit nice and tight. I don't even think about them. The only issue is needing to slightly redish the wheel.
    "Never trust a man in a blue trench coat. Never drive a car when you're dead." -- Tom Waits
    Jun 2014
    Quote Originally Posted by drog View Post
    I really like the numbers on this...except the 2.3 max tire size. Has anyone confirmed how accurate that number is? I like running 2.4 XR3's in the back.
    Jan 2009
    face it, 142 is old news. I still have a 142 axle in a frame that can handle any axle size (Karate Monkey FYI) but if I needed to buy a new frame, I'd just bite the bullet and get a 148 spaced frame and an adapter axle for my hub. personally, I don't feel the need for boost anything, but there's little to be gained by limiting yourself the the very tiny list of frames that are still being made with 142 spacing. if you can find a frame you really like that happens to still have that option, that's great. just don't let it limit your options.
    Sep 2017
    I have Pole Taival and think it's one of the best hardtails money can buy. And you can run it 142 or 148mm in the back with enough clearance for 29x2.5 or 27.5x3
    Sent from my Pixel 3 using Tapatalk
    KVV
    KVV is offline
    May 2017
    IMO, Hayduke geo looks bad with 29 wheels. Even with 2.3, the BB is already too high. It is really awesome with 27x2.8 though.
    smartass
    Reputation: amish_matt's Avatar
    Quote Originally Posted by heartland View Post
    Agreed. I'm running the Boostinator on my I9 hub (frame has 420mm CS) and I don't even know it's there. Redishing is a non-issue it's so simple. If boost adapter endcaps are available for your hub, it's a no brainer.
    Reputation: Mr Horse's Avatar
    I think the RSD Big Chief fits your description and is affordable.
    I believe the frames are on sale but am not sure on what sizes are still available.
    Reputation: OldHouseMan's Avatar
    Definitely get some adapters, then check out the Sexiest AM/FR/Enduro Hardtail thread on Pink Bike.
    Sexiest AM/FR/Enduro Hardtail Thread
    I only ride bikes to fill the time when I'm not skiing.
    Dec 2008
    These go on sale for about $180 from time to time...
    pretty good specs
    https://www.chainreactioncycles.com/.../rp-prod155477
    Jun 2014
    Thanks guys. I think I'm gonna give a boost conversion kit a try. That would really open up my frame choices.
  1. 142x12 single speed frame options
    By Pick in forum Singlespeed
    Last Post: 09-26-2018, 12:48 PM
  2. Any eccentric 142x12 rear hub options?
    By paleh0rse in forum Singlespeed
    Last Post: 04-16-2016, 05:48 AM
  3. Hardtail + 142x12 + sub 5lbs + sub $1k?
    By macace8 in forum 27.5
    Last Post: 12-05-2014, 03:11 PM
  4. 142x12 nice steel 29er frame?
    By APSBiker in forum 29er Bikes
    Last Post: 09-12-2011, 11:07 AM
  5. Powertap SL+ on a 142x12 frame?
    By nathanbal in forum XC Racing and Training
    Last Post: 07-29-2011, 08:14 AM
Members who have read this thread: 101
