1 x10 Shimano anyone?- Mtbr.com
    Front Range Cyclist
    Reputation: juansevo's Avatar
    Curious is anyone out there running say an XX cassette (11-36) with a 30 or 32 up front using a Paul's adapter with a Dura ace 10 speed thumbie? If so what rear der? MRP chain guide? What are you running?
    In the immortal words of Socrates..."I drank what?"
    Facebook.com/monstercrosser
    Twitter: @monstercrosser
    Plays with tools
    Reputation: customfab's Avatar
    I have a frame to build and the customer wants to run a Dyna-Sys 1X10 setup on it. We may go for a XTR double crank so he has the option of a granny if he decides to do marathon races. Not sure what the BCD is on those cranks though, might have to make him a chainring.
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    I have fitted the Shimano XT 11-36 10 speed onto a couple of bikes & it works great why not go that way ?
    Lots cheaper & still works great.
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
    Reputation: OmaHaq's Avatar
    Jun 2010
    Just recently built a commuter for a fellow and set him up with a 1x10.
    SLX 10-speed long cage derailuer. 32-tooth up front. N-Gear JumpStop as suicide protection. I ran a Paul Thumbie and 10-speed dura ace shifter. Indexing works fine. I would not recommend using friction shifting because it was very tough to find gears.
    http://www.treefortbikes.com/product...op--349mm.html
    Personally, I think it is overkill. But you gotta make the customer happy.
