X-Fusion RC32 Volume Reducers- Mtbr.com
Results 1 to 2 of 2
    Feb 2019
    Would the X-Fusion RC32 120mm 9mm QC fork be a better susupension fork than my stock SR Suntour XCM30 120mm 9mm QC fork on a 2018 GT Verb Sport? If so are there volume spacers for X-Fusion RC32? Iím on a tight budget having just bought a Rock Shox Monarch RL for the rear. Any budget fork recommendations would be greatly appreciated. Cheers!
    Reputation: dbhammercycle's Avatar
    I would think that the X-Fusion would be a better fork than the Suntour. I think you use volume spacers for rear shocks and travel reducers for the front suspension. I know the Velvet has a travel reducer to be used with a 27.5 wheel since it was designed as a 26er fork. So, are you asking whether you can reduce the travel on the X-Fusion or adding a reducer so that the fork doesn't bottom out completely? The Velvet has a pin you can move to change the fork travel and I imagine you can do the same with the RC32. I would also imagine you can find a reducer for the fork, but wonder why you would. Best to ask the shop you would be purchasing the fork from.
    I don't know why,... it's just MUSS easier to pedal than the other ones.
  1. Need CC DB air volume reducers.
    By darkslide18 in forum Banshee Bikes
    Last Post: 11-18-2014, 08:41 AM
  2. X-Fusion PVA O2 bushings and reducers
    By Merida OneFiveO880 in forum Downhill - Freeride
    Last Post: 09-07-2013, 07:35 AM
  3. X-Fusion Velvet Volume reducers (too linear)?
    By CrozCountry in forum Shocks and Suspension
    Last Post: 07-07-2013, 02:20 PM
  4. Volume! Volume! Volume! (BCOS on bad behavior)
    By GRAVELBIKE in forum Colorado - Front Range
    Last Post: 12-04-2011, 09:24 PM
  5. Fox Air Volume Reducers on Trance X
    By itchyjesus in forum Giant
    Last Post: 08-23-2011, 08:54 AM
