is it worth it to make a 27.5/26 mullet bike?- Mtbr.com
Results 1 to 10 of 10
    Oct 2018
    so i put a 26 inch rear wheel from my old mtb on my 27.5 in xc hardtail, and i like how it feels. especially when jumping around or manual-ing.
    would it be a bad idea to keep it that way? i like how slack it is, and the reduced reach makes it a very comfortable ride, but i'd need to put a hub in the center of a 26in hoop, because my old mtb's wheel doesn't have a mount for disc brakes
    If You didn't start on a Hardtail you're doing it Wrong
    Reputation: natas1321's Avatar
    Nov 2017
    if it makes you happy and puts a smile on your face why not.
    XC iconoclast
    Reputation: richj8990's Avatar
    Apr 2017
    I hated it. Well, that's too strong of a term...I didn't like it. I tried it off and on for a couple of years. Keep in mind this was not a plus tire in back, it was a 26x2.4. Climbing was slow and tedious with a taller tire up front. Stability was worse in back with a smaller tire, even if the width was the same as the normal 27.5 tire in back. I didn't notice any advantage in acceleration. Only disadvantages. Maybe a smaller plus tire in back has advantages.
    A smaller plus tire in front, that I absolutely love, 26 x 2.8 front, 27.5 x 2.4 back. That is great for XC/lighter trail riding. If it's hardpacked the plus tire will be a little slower but if it's rocky/chunky it's a great setup and the plus tire up front is in general faster than voluminous (2.4, 2.5, 2.6) 27.5/27.5. I have no idea why more people don't try 1/2 plus, either with the same height of tire in front or one height size down. I'm also trying it with 27.5 x 2.8 / 27.5 x 2.4 and that combination is scary fast on some trails, it's a bulldozer. It doesn't feel faster, it actually feels slower, like I'm in slow motion with such a tall 28.4 inch tire, but I look at the segment numbers and I'm like WTF how did I just go that fast? I can see why people love 29" because of the speed/momentum factor, but I'll stick with 27.5 for now. Because...if it's a wider tire, it's really not 27.5 inches high: 2.6 is usually 28 inches high, and 2.8 is usually 28 1/2 inches high. That's enough rollover and clearance to really go fast on the straights without the handling penalty of a 29".
    May 2013
    I have made a few mullet bikes in the past that I kind of liked. It was back when 26" ruled the day. One was a Pivot Mach 5.7 with 26" rear and 27.5 in front. Also an Ibis HD3 with similar setup. Both were great light endure setups in their time. Also I put a 29" front wheel on a 2014 (27.5") Pivot Mach 6 frame. That worked out kind of interesting too.
    My 2.35 hans dampf 26er was taller overall than my 2.3 purgatory in 27.5.
    The only way you can get a significant "mullet" setup is to run a 2.1 26er and a >2.4 27.5 up front. Then you have poor rear traction and a wonky bike anyway.
    Theres no benefit or reason to use a 26 wheel. Its inconsequentially smaller, rim choice sucks, tire choice sucks.
    May 2013
    Quote Originally Posted by One Pivot View Post
    The reason for using a 26" wheel on back would be because 26" is what your frame is designed for. And you still want to get some use out of the bike. In that case a 27.5" front wheel can work fairly well.
    Yes, but the thread is about putting a 26er wheel on a 27.5 frame.
    Reputation: MSU Alum's Avatar
    You tried it. You liked it.
    I guess the question is, do you now prefer it over 27.5 front and back?
    Only you can answer that.
    I wouldn't do it, but so what?
    Feb 2019
    Most importantly, it is your bike and your money .... if you like it, then go for it!
    However, you could be enjoying the benefits of a slacker geometry more than you are enjoying the 26" rear wheel. I wonder if you could get a similar feel, and have more fun, by increasing the travel on your fork.
    Reputation: cookieMonster's Avatar
    My main bike is a 26er that happened to fit a 27.5 in the front with plenty of clearance in the fork. I run Minions front and rear, and the 27.5 is actually only .5 bigger in diameter.
    It slacker out the bike from 65.5 to 65 degrees; barely noticeable. The only thing Ive noticed is very slightly more traction up front. Id probably put a 27.5 wheel in the back but theres not quite enough clearance.
    I dont think Id put a 26 wheel on a 27.5 bike though.
  1. Replies: 22
    Last Post: 09-28-2019, 09:51 AM
  2. mullet bike? 27.5 front, 27.5+ rear, 29er frame
    By minhinmonterey in forum 29er Bikes
    Last Post: 01-13-2018, 08:29 PM
  3. Replies: 8
    Last Post: 11-01-2014, 12:20 AM
  4. To mullet or not to mullet, that is the question...
    By hardwarz in forum Beginner's Corner
    Last Post: 06-14-2011, 12:29 AM
  5. help change my mullet to a 9 speed from a 27
    By dckiteboards in forum Downhill - Freeride
    Last Post: 04-20-2007, 10:56 PM
Members who have read this thread: 84
