Upgrades for 2017 Giant Stance 2- Mtbr.com
Results 1 to 5 of 5
    Dec 2018
    I am upgrading a few things on my 2017 Stance 2 and have a few questions for all you smart MTB folks.
    1. Will the sport tracker disc hubs accept an 11 speed cassette?
    2. Can I fit a 180mm disc on the rear? I installed SLX disc brakes on the bike.
    3. When I convert the front cranks to a Shimano SLX without replacing the stock FSA press fit bottom bracket or should I replace it with a Shimano press fit. Also, do I need spacers to ensure the sprocket is centered with the rear hub?
    Thank you for any assistance with this.
    Never trust a fart
    Reputation: frdfandc's Avatar
    The hub should fit 11 speed without issue.
    Yes you can install a 180 rotor on the back. Just get the appropriate caliper adapter.
    Get the Shimano press fit. It will guarantee a proper fit. All spacers required should come with the crank set. Make sure to follow all directions to the letter.
    Dec 2018
    Sweet, thank you for the reply. I am going to start the upgrade after the new year once I get back home. No spacers came with the cranks but it looks like the FSA cranks have a spacer. Am I wrong for thinking the chainring should be somewhat centered with the rear cassette? Thanks again for the reply. John
    Shimano Hollow Tech II and FSA Mega Exo both use a 24mm Crank Spindle. Should be able to switch those out without replacing the Bottom Bracket(BB).
    Find out exactly which BB is in the Stance. Or measure both ends to make sure they are 24mm.
    Here is a BB chart to show compatibility from Wheels Manufacturing
    https://wheelsmfg.com/complete-crank...-adapter-guide
    Dec 2018
    Good job! Thank you
    Quote Originally Posted by rusheleven View Post
    That helps a lot, Thank you. I have been reading everything I could and read where someone had used the FSA press fit. I don't want to change it out unless I have to just because I have not purchased a puller or press to do the job correctly. Happy Trails and Happy New Year. John
  1. 2017 Giant Stance - weight and reviews?
    By ultraclyde in forum Giant
    Last Post: 11-18-2016, 09:42 PM
  2. Replies: 19
    Last Post: 10-03-2016, 07:58 AM
  3. 2011 Giant Trance X2 vs 2015 Giant Stance 2
    By bionicledude in forum Giant
    Last Post: 07-22-2016, 04:42 PM
  4. 2016 Giant ATX vs 2015 Giant Stance 2
    Last Post: 06-13-2016, 10:42 PM
  5. Replies: 3
    Last Post: 04-30-2016, 07:06 AM
Members who have read this thread: 4
