Thru Axle beep-beep- Mtbr.com
Results 1 to 5 of 5
    Feb 2018
    Thru Axle beep-beep
    Hi,
    I ride with a Commencal Meta, with SLX FH-M7010 rear hub, 12x142mm Thru Axle system. Formerly, I used the Sram Maxle Ultimate Thru Axle, now, I use Sram Maxle Stealth, because of simplifying, and weight reducing of my bike.
    My problem is, that I formerly realised, when I used the Maxle Ultimate, that my wheel is setting up strange noise, like beep-beep-beep-beep... It is not very loud, but it is firm and rytmicall, it seems it is related with the wheel's turning, one turn, one beep.
    Later once, totally occasionally, by a puncture, I left the axle a little bit lighter, not so stiff, and the noise disassembled.
    But now, when I use the Stealth Axle, It started again the symptoms, and now it seems to be a problem, because the stealth axle I cannot leave to loosener, because I will lost my wheel during a harder ride.
    Have you ideas, what could be it? Is it maybe because of the hub, or the frame, or whatever else?
    Thanks, sincerely: wmtv
    Reputation: Hurricane Jeff's Avatar
    Try a light film of grease on the axle and threads.
    EXODUX Jeff
    Feb 2018
    Normally, I always greasing every threads to avoid corrosion, so I am not sure, but I will try your idea again.
    Thank you.
    Jan 2019
    i would rather use anti-seize instead of grease. It is much more resilient and doesn't affect thread torgue as much as grease does. you could use grease on the non-threaded part of the axle and anti-seize onto threads.
    Jun 2017
    Brake rotor alignment, or bent rotor?
  1. Need help. 9mm thru axle to a 15mm thru axle.
    By specialized11 in forum 29er Bikes
    Last Post: 07-05-2013, 03:33 PM
  2. Replies: 4
    Last Post: 06-19-2012, 04:52 PM
  3. Replies: 0
    Last Post: 09-02-2008, 06:57 AM
  4. Has anyone heard of the Beep Test? (Running)
    By RideFaster in forum General Discussion
    Last Post: 03-03-2006, 03:26 PM
  5. Replies: 4
    Last Post: 11-05-2004, 06:26 PM
