Are there any 27.5 rims that will work with V-brakes- Mtbr.com
Results 1 to 9 of 9
    I have an Ibis silk ti that want to setup with 27.5 wheels. The rear is v-brake only. I was wondering if there were any v brake compatible rims out there.
    Quote Originally Posted by Haystack Calhoun View Post
    If you go to the drop down menu on prowheelbuilder they have a rim finder tool. You can search for just 650b/rim brake. Looks like they only have a couple velocity models for you, but you could call them too.
    Sometimes the Chinese carbon outfits have sort of odd combos like that... Might be worth a look.
    Good luck!
    Sent from my Moto G (5) Plus using Tapatalk
    Reputation: seat_boy's Avatar
    Have you measured to make sure your V brakes have enough reach to work? I'm assuming you're converting a 26" frame.
    Velocity Quill, Soma Weymouth, and Velo Orange Voyager are a few rims that come to mind.
    http://www.bikingtoplay.blogspot.com/
    RIGID, not "ridged" or "ridgid"
    PEDAL, not "peddle." Unless you're selling stuff
    Reputation: Hurricane Jeff's Avatar
    You might find the rims but unless you have relocated your brake studs, V brakes will not work. Since its Ti, why not have a Ti frame builder convert it to disc brakes?
    EXODUX Jeff
    Reputation: MSU Alum's Avatar
    Quote Originally Posted by Hurricane Jeff View Post
    I was thinking the same thing. Compatibility would be my concern, although looking at some V brakes online, it does look like the radius has some adjustability.
    Ride what you like!
    Reputation: MattiThundrrr's Avatar
    Jul 2019
    See the slot that the brake shoe is mounted in? That's the adjustability. Are there any 27.5 rims that will work with V-brakes-tektro-926al-mini-v-brake-single-p221031-361930_image.jpg Some vees don't have that feature. Not sure if it'd span the distance from where it needs to be on a 26 rim vs 27.5. Logic dictates that you'd need .75" of adjustment range to make up the difference (1.5" bigger rim diameter/2 to get radius)
    The revolution starts now
    When you rise above your fear
    And tear the walls around you down
    The revolution starts here
    Reputation: Redlands R&C's Avatar
    Dec 2013
    Quote Originally Posted by MattiThundrrr View Post
    See the slot that the brake shoe is mounted in? That's the adjustability. Click image for larger version.
ID:	1306191 Some vees don't have that feature. Not sure if it'd span the distance from where it needs to be on a 26 rim vs 27.5. Logic dictates that you'd need .75" of adjustment range to make up the difference (1.5" bigger rim diameter/2 to get radius)
    Most V-brakes even with that adjustment range will not reach properly to a 27.5/650b rim. You can buy on eBay some v-brakes with extra long reach adjustment, but those are a poor solution as it changes the pull ratio some and they never feel as good because of that. I've tried a few times for customers and the results have always been sub-par.
    OP, I agree, the best bet (while costly) is to have a ti-frame builder weld on a disc tab/brace for the rear end of the bike. I know the guys at Dean Bikes do a fair amount of modifications to older frames, there is always a merlin/litespeed in there that is getting a modern headtube or disc tabs welded on.
    Silly bike things happening.
    It's not a 1.5" diameter difference, it's only 1" (559 BSD to 584). So you need 0.5" of vertical adjustment.
    Many people have reported that the Tetkro CR-720 canti has enough adjustment for this to work.
    Ride what you like!
    Jul 2019
    Lol I said "logic dictates". Nothing logical about 27.5, I guess
  1. Replies: 4
    Last Post: 08-20-2015, 11:56 AM
  2. Replies: 0
    Last Post: 02-06-2015, 04:58 PM
  3. Rims, rims rims rims...
    By snaky69 in forum Urban/DJ/Park
    Last Post: 05-30-2006, 05:10 AM
  4. Replies: 4
    Last Post: 12-07-2005, 11:51 AM
  5. are there anygood rims out there?
    By finchy in forum Downhill - Freeride
    Last Post: 11-27-2004, 04:22 PM
