Results 1 to 3 of 3
    Surly1x1 + 29"tire
    what tire do you have on your Surly1x1?
    i want to build a 69er with this fork, so i need to know which is the biggest tire you can put on?
    i think it's one of the best rigid fork for building a 69er because it has a short AtoC (413mm) and a quite big offset (45mm).
    please put your photo or comment.
    thanks!
    mircea
    compassion for all beings
    Ovaries on the Outside
    Reputation: umarth's Avatar
    2.1s are tight in the fork. Go to flickr.com and search "Surly 1x1 29er" and you'll find some photos. Since a 29er front will make the headtube angle more slack anyway, the Instigator fork has more room, though it is taller.
    fit a 2.35 rampage on a sun ringle eq23 rim in my 1x1 fork. only about 1cm of clearance but it fit.
