Stuck Yeti SB5c collet bolts- Mtbr.com
Results 1 to 5 of 5
    Mar 2019
    Hi all,
    Wonder if anyone can provide any advice?
    I'm trying to change out the bearings on my 2015 Yeti SB5c. I've got the bearing rebuild/replacement kit and all was going well until I got to the 2 collet axles (one that holds the rear triangle to the switch infinity and the other that holds the rear triangle to the "Link SB5C" (the black link next to the the switch infinity)).
    I've taken out the outside bolts but when I've tried to unscrew the collet axles using the 10mm allen/hex, the bolts are stuck to the left hand side of the bike. Unscrewing them just prizes apart the rear triangle which ultimately will probably crack it.
    These are number 36 and 37 on page 27 of this PDF:
    https://assets.yeticycles.com/static...0bf9127a51.pdf
    I've tried wd40, grease etc but the bloody things wont pop out.
    Does anyone know of a trick to free them up?
    Cheers, Andy
    Post in Yeti forum. You’ll get much better answers there.
    Biking Like Crazy!
    Reputation: blcman's Avatar
    Have you taken the collet wedges out? Those are separate from the bolts.
    Stick an end of an allen wrench in there and wiggle to get them out.
    2018 Santa Cruz Nomad
    2018 Banshee Prime
    2018 Banshee Rune
    2016 Hightower OG
    2017 Niner Rip 9 RDO
    2014 Knolly Podium
    Mar 2019
    @mnigro - ok will do.
    @bicman - yup, I took those out. A friend gave me some advice to use wd-40 and heat up the area with a hairdryer a bit - I'll give that a try.
    Jun 2020
    Wanted to feedback how great and informative your videos are...you're definitely punching far above the number of views listed and its only a matter of time before you start getting some heafty traffic!
    Tutuapp 9apps Showbox
  1. SB5C correct collet bolt torque ?
    By avi66 in forum Yeti
    Last Post: 05-21-2019, 12:08 PM
  2. Anyone upgrade SB5C v1 to SB5C v2?
    By easyrider1977 in forum Yeti
    Last Post: 01-25-2018, 09:11 AM
  3. Replies: 42
    Last Post: 01-27-2017, 09:26 AM
  4. Stuck Collet Nut in BLTc linkage
    By sooner518 in forum Santa Cruz
    Last Post: 03-11-2012, 11:17 PM
  5. bolts bolts bolts
    By gic in forum Weight Weenies
    Last Post: 08-26-2004, 11:56 AM
Members who have read this thread: 13
