Sram NX 1x11 vs NX Eagle 1x12- Mtbr.com
Results 1 to 19 of 19
    Aug 2018
    Pros - cons? Worth the cost?
    Apr 2016
    I would say it's worth it, my bike is 1◊11 and I just demoed a nx 1◊12 for 3 days and it makes a bigger difference then you would think. There's a bigger range on the top and bottom end so you don't max out going down hill nearly as fast, plus you can climb anything
    Sent from my SM-G920P using Tapatalk
    Reputation: MSU Alum's Avatar
    If you don't need 1x12, 1x11 is fine. If you need the range, get 1x12.
    I don't know, is it worth it to you?
    Reputation: LyNx's Avatar
    What's wrong with your current 11spd setup? I just don't get all the fuss, I'm still quite happily on 10spd and only made that switch from 9spd 2 years ago Current setup includes a 2x10 with 24/36 rings and 11-36 cassette on my 33lb FS 29er and a 1x10 32t ring/13-42 cassette on my rigid 29+, with an emergency 24t installed on the crank, but no FD, just in case, but can't really use my 2 largest cogs running 3" tyres anyways, so the 32-42 is my lowest/easiest gear anyways. FYI, I love climbing.
    Quote Originally Posted by Harold
    You're doing mtbr wrong, you're supposed to get increasingly offended by the implications that you're doing ANYTHING wrong.
    I dont see the point with 50cog on 650b wheels. On 29 yes, but 650b climb so much better in steep and or chunky. I am in co front range, steep and rocky is typical here and my max rear is 42, but honestly 95% of time i stay in 36. Now this summer i demoed bunch of 29ers and the sluggishnes of bigger wheels forced me to use 46 and 50 a lot. 32 front on all bikes.
    Sep 2018
    I've been riding Sram NX 1-11 11-42 for about 3 months now with a 32t oval chainring and i can tell you the range its limited, there are very rare special cases (22% climbs) where the range just isn't there to climb, and i assure its not an issue of "get good". Nevertheless i will fix it changing the cassete to a 11-46 sunrace. That way i boost my range and i don't need new components.
    11-50 with 32 chainring sounds for climbing walls
    Just my two cents here!
    Reputation: RS VR6's Avatar
    11 through 42 on the 12 speed is the same as the 11 speed. All SRAM did is add the 50T. So if you need the 50T...the get the 12 speed...or you can do what some of the other guys are recommending and get a 11sp 11-46 cassette.
    Reputation: brankulo's Avatar
    Aug 2005
    Quote Originally Posted by bryan1321 View Post
    with 11-42 and 32 front you will be fine on 20% grades. if you need more range get 10-42 cassette.
    Mar 2017
    I went with a 28t chainring with my GX 1-11 and it's great as long as you don't want to win downhill races on pavement. If I ever do upgrade to Eagle, I'll go back to a 32t chainring.
    NedwannaB
    Reputation: JMac47's Avatar
    Quote Originally Posted by brankulo View Post
    You need an XD drive hub to run a 10t cog. Could be wrong, but it doesnít seem like the OP is looking for a higher top end.
    Ripley V1 XC/Gravel Adventure rig
    NINER Rip9 RDO(future...)
    Salsa Timberjack
    Reputation: brent701's Avatar
    Sep 2012
    It's only worth it if your area calls for the gearing
    I have GS eagle on 4 bikes. Never use the 50T. The 10 is nice but I am never in it long enough to actually tell if it is making me faster or not.
    I usually run a XT 11-42 or a XTR 11-40 or my SS which is 90% of my riding and all of my racing
    Too Many .
    NedwannaB
    Quote Originally Posted by RS VR6 View Post
    NX Eagle is not same as NX 1x11 so the 50t is a mute point. Reading comprehension. Just saying...
    Salsa Timberjack
    NedwannaB
    Quote Originally Posted by brent701 View Post
    Respected but your area is irrelevant to what the OPís needs are. Just sayn...
    Salsa Timberjack
    Sep 2012
    Quote Originally Posted by JMac47 View Post
    Well all the OP did was ask pro can worth the cost
    So not sure what he needs really are
    The NX eagle is cheap
    150-200 new take off. It uses a standard shimano 10 speed driver.
    Truthfully if you needed picked between the two NX Systems. Get eagle. Never know if you would need the 50 or not.
    Too Many .
    Apr 2014
    I'm old and ....uh chunky. My socal trails are long and steep. I had the 42T and made the switch to Eagle. Yeah...it was worth it.
    NX Eagle uses a Shimano driver, GX Eagle uses an XD driver.
    If you have NX 11sp now, itíd be a whole lot cheaper to buy a Sunrace 11-46 cassette and just ride it till you need a full upgrade.
    GG Megatrail (Frameset for sale)
    GG Trail Pistola 27+/29 (speedy)
    RSD Middlechild 27+ (punky)
    Pivot Shuttle 27.5 (wifeys)
    Aug 2014
    When you really need that eagle range, it's very nice to have.
    Rides all the bikes!
    Reputation: Sidewalk's Avatar
    May 2015
    1x11:
    Less weight
    Less range
    Cheaper parts
    1x12:
    More weight
    More range
    Less cheap
    If you have the option to use an XD driver, I'd rather run GX 10-42 than NX 11-50.
    Personally, where I ride, I like 10-50. And I have pretty strong legs.
    Quote Originally Posted by Nurse Ben View Post
    I agree.
    monster member
    Reputation: Wheelspeed's Avatar
    Well, you asked for opinions, so mine is that if my bike already had 11 speed, I'd leave it like that. Sounds like a lot of people think 11-speed is a little less finicky to keep adjusted properly vs the 12-speed. And like others said, you shouldn't need that big 50 tooth cog on a 27.5" wheel bike.
    By the way, someone above who tested some 29ers didn't have some details quite right. Being in the same gear ratio, like 30 x 46 on two bikes climbing a hill, one on a 27.5" wheel and the other bike a 29er, would not be at the same ratio. The 29" wheel has a bigger radius, so travels further with each revolution. Making these numbers up- but a 29er climbing in a 30x46 ratio might be similar to a 27.5" bike climbing the same hill in a 30x44 or maybe a 30x43 ratio. So, a 29er in a ratio you use for a 27.5er feels harder to pedal, but a large reason for that is because it's a different overall ratio. Absolutely right that there's more rim and tire weight, but also definitely a different overall ratio.
    Have fun!
  1. Sram Eagle 1x12
    By marekvag in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-09-2019, 10:58 AM
  2. XT M8000 1x11 11x46 or GX Eagle 1x12 11 50
    By syndragon in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-10-2018, 01:02 PM
  3. DIY Upgrade SRAM 1x11 to Eagle 1x12 mini group on 2015 Specialized Stumpjumper FSR 29
    By pipots in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-01-2017, 08:29 AM
  4. Sram Eagle 1x12
    By marekvag in forum The ReCycle Bin
    Last Post: 03-23-2016, 09:24 PM
Members who have read this thread: 21
