• 05-06-2020
    mike2020
    Rockshox Pike 27.5 mudguard problem
    Hello,
    Does any of you guys had problem using mudguard on B1-B2 (2018 and up) boost Pike ? On mine pike, the crown goes lower than the fork bridge at bottom out and tear down the zip ties on mudguard. I had a few different forks before and none of them had this problem.
  • 05-07-2020
    Tommy E
    None of my pikes (newer style 2018 up) are like what you have pictured. All of mine are flush or very close to flush. What's that shiny filed, scratched or impact mark on the fork from?
  • 05-07-2020
    mike2020
    Thank you for an answer. That shiny spot is just a reflection on glossy protective foil. Are your forks boost ? Maybe this problem is only on a boost forks.
  • 05-08-2020
    Tommy E
    Mine are boost. Both are rct3 forks. One is on a 27.5 x 2.8 roscoe and the other is on a 29 x 3.0 stache. The 27.5 fork I have is the newest style that is machined for the torque caps on the dropouts and the shaping looks exactly like what you have pictured here with the exception that the steerer tube on mine is almost flush.
  • 05-08-2020
    mike2020
    Then I don't have a clue why is it like this. It really pisses me off. My next fork definitely won't be a rockshox.
