    Feb 2006
    Rim Brakes reported to convert to 650B
    Tektro CR720
    Tektro Onyx
    Paul Motolite BMX
    Avid tri- align
    Cane Creek curve
    FMF BMX V-brake
    These are brakes I have seen as claiming to be compatible with canti studs on a 26"-650B conversion. I have read that you need 12.5 MM of brake pad adjustment. to work.
    If anybody has 650B axle to rim center measurement please post as well as any other rim brakes that might work.
    Feb 2006
    Thanks for that, I will add FMF to the list, Can you give a measurement if you still have that set up. Axle to rim center and canti stud center to brake pad bolt center.
    approx. measurements
    292/293mm axle to rim center
    canti stud to brake pad bolt 38/39mm (the FMF is adjustable 20mm below this and 25mm over this.
    canti stud to cable bolt 108mm
    The last measurement is important since that tells you if the cable will clear the tire tread. I don't have a bike set up for these anymore but I just tossed a 650b wheel with a Quasi-Moto into a Kelly 26" fork with brake studs and you need 100mm(from canti stud to cable) to clear the tire by about 5mm or so. I'm not sure if all the brakes you list will clear.
    Quote Originally Posted by Fred Smedley View Post
  1. Convert 650B to 26/29er
    By Chrisa66 in forum 27.5
    Last Post: 11-22-2010, 10:25 PM
  2. Convert Trek 6000 to 650b
    By Mr Pink57 in forum 27.5
    Last Post: 08-17-2010, 07:41 PM
  3. Convince Me To Convert 650B SS
    By Hand/of/Midas in forum 27.5
    Last Post: 12-16-2008, 07:41 PM
  4. Replies: 7
    Last Post: 07-12-2008, 05:08 PM
  5. Tracer Owners- anyone convert from 26 to 650B?
    By Molasses in forum Intense
    Last Post: 01-09-2008, 02:48 PM
