Problems installning front derailleur on a chinese carbon FS frame!- Mtbr.com
Results 1 to 3 of 3
    Apr 2013
    I`ve got some problems installing the Shimano XT-M780E front derailleur on my Yishun FS frame (FM169, should be the same frame as Hong Fu, Deng Fu and I-PLay FS-frames). The hole through the bottom of the frame that the gear cable runs through doesn`t match up with the wire connector on the derailleur, it looks like the hole is a little bit too far back compared to the the derailler so it`s impossible to connect the wire in the way it should be routed through the derailleur.
    Hs anyone else experiencd anything like this with the chinese S-fames?
    Reputation: giantdefy's Avatar
    Jun 2010
    Pictures?
    Apr 2013
    I don`t know if it`s easy to se the misalignment on a Picture but I have routed the wire on the "wrong" side of the derailleur so know it works. I will try to take a Picture of it also...
  1. Front Derailleur Adjustment Problems
    By rick5587 in forum General Discussion
    Last Post: 08-27-2013, 10:22 AM
  2. Replies: 0
    Last Post: 07-06-2013, 08:09 PM
  3. Problems with front derailleur
    By Blueliner in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-03-2013, 11:28 AM
  4. Front Derailleur Problems
    By Honda Guy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-09-2011, 05:50 AM
  5. not just a chinese carbon frame, but 90% chinese!
    By menusk in forum Bike and Frame discussion
    Last Post: 06-22-2011, 01:53 PM
