P35 and smaller tires, (38-42c.)- Mtbr.com
Results 1 to 5 of 5
    Full Tilt Boogie
    May 2005
    Has anyone run a combo similar to this? I have a late 50's Schwinn tandem with 650b wheels that needs new wheels. The P35 is most similar in dimension and looks to the original steel ones, and the Fatty Rumpkins would be a killer tire for it's intended use.
    Thoughts or photos? Thanks.
    I sell bikes here. Check out the Blog here. Facebook.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by benwitt11
    I have used 26x1.5" road tires on 32mm rims with no issues.
    What brakes are on the tandem?
    mtbtires.com
    Full Tilt Boogie
    May 2005
    Quote Originally Posted by shiggy
    The front has an exquisite drum brake hub with huge flanges, the rear will be a coaster brake Nexus 7spd to replace the SS Bendix. I want to ride it, and gears are the way to make that happen.
    Attached Thumbnails Attached Thumbnails P35 and smaller tires, (38-42c.)-3.jpg
    Dec 1998
    Very cool, hub and frame.
    mtbtires.com
    Full Tilt Boogie
    May 2005
    It's fillet brazed...
