offsets?- Mtbr.com
Results 1 to 6 of 6
Thread: offsets?
    Aug 2019
    offsets?
    I have a Giant talon 3 and it has a 42mm offset. Can I use a fork with a 55mm offset?
    Reputation: MSU Alum's Avatar
    Of course. Are you just asking what the effect would be?
    Aug 2019
    Quote Originally Posted by MSU Alum View Post
    Well , that too...lol Thanks.
    Reputation: Bluegill's Avatar
    Mar 2018
    The increased offset will decrease the "trail" - it should have the result of quickening your steering response. This could be good....or bad. Depends on how you like it.
    Quote Originally Posted by Bluegill View Post
    Yeah, and not just a slight decrease in trail. 13mm is a big difference. Most would find the steering to be too twitchy. OP, I wouldn't do it unless you plan on running really high volume plus tires that will put you close to 29'er size. We've seen big wheels run shorter offsets with other geo mods, but there's a reason we dont' see smaller wheels with longer offsets. If you're doing it because you can get a good deal on a 55mm offset fork, it's not worth it.
    Mar 2018
    You could always calculate the change in trail with your known head angle and the current and proposed offsets.
  1. Rim or HUB(rear) Offset? Frame Offsets? What happed?!
    By SPY.vs.SPY in forum Wheels and Tires
    Last Post: 12-07-2014, 07:20 PM
  2. Fork offsets
    By vicgarcia in forum 29er Bikes
    Last Post: 08-29-2014, 05:15 AM
  3. Replies: 152
    Last Post: 05-31-2013, 11:23 AM
  4. Hurricane Fat Boy - a fork up for non offsets?
    By fatchanceti in forum Fat bikes
    Last Post: 03-14-2012, 04:11 PM
  5. List o' various 29er fork offsets
    By hellocook in forum 29er Bikes
    Last Post: 10-27-2011, 10:54 PM
