offsets?
Printable View
  • 10-26-2019
    macman4
    offsets?
    I have a Giant talon 3 and it has a 42mm offset. Can I use a fork with a 55mm offset?
  • 10-26-2019
    MSU Alum
    Of course. Are you just asking what the effect would be?
  • 10-26-2019
    macman4
    Well , that too...lol Thanks.
  • 10-28-2019
    Bluegill
    The increased offset will decrease the "trail" - it should have the result of quickening your steering response. This could be good....or bad. Depends on how you like it.
  • 10-29-2019
    slimat99
    Yeah, and not just a slight decrease in trail. 13mm is a big difference. Most would find the steering to be too twitchy. OP, I wouldn't do it unless you plan on running really high volume plus tires that will put you close to 29'er size. We've seen big wheels run shorter offsets with other geo mods, but there's a reason we dont' see smaller wheels with longer offsets. If you're doing it because you can get a good deal on a 55mm offset fork, it's not worth it.
  • 10-29-2019
    Bluegill
    You could always calculate the change in trail with your known head angle and the current and proposed offsets.
