Results 1 to 5 of 5
    Nevegal bigger than a Neo-moto ?
    Does the 2.35 Nevegal have more volume than the 2.3 Neo-moto ? I am running a Pike w/ the Neo. and have wonder if the Nevegal is much bigger ? Have about a 1/4" to the arch to work with. Thanks
    wwg
    wwg is offline
    No Class
    Reputation: wwg's Avatar
    I, too, would like to know the answer to this.
    check shiggy's website
    www.mtbtires.com
    Its a great site that lets you compare the actual sizes of the tires to see the differences.
    Reputation: HTR4EVR's Avatar
    Here is the Nevegal 2.35 in a Rocksox Revalation...
    Ovaries on the Outside
    Reputation: umarth's Avatar
    Shiggy posted this on another thread.
    Dimensions:
    Nevegal 27.5x2.35
    Tread width: 60.9mm/2.40"
    Casing width: 56.3/2.22
    Casing height: 52.5
    Volume index: 29.6
    Weight:749/753g
    Nevegal 27.5x2.10
    Tread width: 55.6mm/2.19"
    Casing width: 53.7/2.11
    Casing height: 50.6
    Volume index: 27.2
    Weight:630/632g
    For comparision
    NeoMoto 650Bx2.35
    Tread width: 59.5mm/2.34"
    Casing width: 55.8/2.20
    Casing height: 51.3
    Volume index: 28.6
    Weight:707/708g
    Nevegal 26x2.35
    Tread width: 60.7mm/2.39"
    Casing width: 54.6/2.15
    Casing height: 51.3
    Volume index: 28.0
    Nevegal 29x2.20
    Casing width: 54.2/2.13
    Casing height: 50.5
    Volume index: 27.3
    __________________
