Results 1 to 13 of 13
    Neo Moto 2.3 sidewalls weep like a drama queen
    Of all my TLR and regular tires converted to tubeless, only my Neo Moto 2.3 weeps horrifically if I don't ride that bike for a week or so (while using other bikes). Seals up nicely, laid on side and swirled sealant overnight after each re-install.
    Anyone else experience this?
    Anything to be concerned about even if psi is checked pre-ride?
    Did a search and seems it's common but odd how none of my tires weep one pin drop. Just the NM2.3
    I don't know what sealant you use, but me homebrew stuff weeps through those tires (actually just the anti-freeze). No problems though. It's a reminder to me that my sealant is still fresh. When I don't get any more weeping it's time to replenish. Great tires for me.
    Okay! I use Wadester's homebrew recipe off mtbr
    Quote Originally Posted by 88 rex View Post
    dwt
    dwt is offline
    Reputation: dwt's Avatar
    Quote Originally Posted by westin View Post
    No problem with my 2.1's. I have a 2.3 that weeped a little, but only in a few places on the sidewall. Aplied a few dabs of Gorilla Superglue, sealed forEVAH (OK, last 2 ,months)
    Old enough to know better. And old enough not to care. Best age to be.
    Initially so much weeping on the embossed lettering. Some what weeping now.
    Mar 2011
    Mine don't leak/seep/weep.
    I use Stan's No tubes sealant.
    same for me with the stans no tubes sealant >>>> no leaks ........
    www.derbyrims.com
    Reputation: derby's Avatar
    Stan's only foam and leak through the sidewall a little for the first few hours in a new tire. Been using it for a few years in Neo-Motos.
    More Torque
    Reputation: Diesel~'s Avatar
    Mine has wept more as it has aged. Did not weep much at first, but after about 8 months, I lose about 1 scoop of Stan's per month.
    -D
    Aug 2010
    I run Stan's....mine didn't leak until I was out riding a 37 mile ride and the psi was a tad low and I burped. I then pumped it up to about 40-45 psi to get it to seat again and that's the only time I've seen the Neo's weep=extreme psi, now that it back to being around 28-30 psi, it's fine.
    Running Stan's in Quasi's and Neo's with no problems. One Quasi weeped a little more but that's it. These are holding air really well for me so I keep holding off trying some Wolverines.
    Dec 2009
    Seems to be your problem.
    Funny.... I've had weeping on Nevegals and especially Conti's, but not Neo Motos. Never saw any problems associated with it.
