Need help with parts- Mtbr.com
Results 1 to 6 of 6
    May 2020
    I am trying to figure out what the best approach is to this problem. I recently broke off the release lever on the front wheel. So, I now have to replace it or replace the wheel(s). Here is what I know about the bike. It is a 2009 Specialized full suspension Stumpjumper with DT Swiss X420SL wheels. I have 9 gears and disc brakes. I have had to replace the front fork with a Fox 32 suspension. Here is what I need help with:
    1) I found out that the through bolt is 9mm. I was able to find a 9x100 front through bolt but when I took a tape measure to the length of the broken bolt it was more like 13xmm long. Am I measuring the correct bolt length or will the 9x100mm bolt fit that wheel
    2) if it will not fit the wheel, then what wheels should I replace the current DT Swiss X420SLs with?
    Finally, please do not reply with "You should get a new bike". That is not an option at this time. It might be once my employment situation is more stable post COVID, but right now I don't really have the $ to spend on a new bike. I want to fix this one in as cost effective a way as possible.
    Reputation: Bacon Fat's Avatar
    Mar 2016
    Are you sure it is 9mm and not 15mm
    Front Wheel Retention Systems: What Do You Need?
    May 2020
    I have the broken bolt and measured the diameter. It is 9mm. I am assuming that they are speced with the diameter.
    Mar 2016
    The bolt will measure longer than what the specs say, The 100mm is width of the hub between the fork drop outs. the 9x100 should work
    May 2020
    Great. Thank you. Figuring out what the right parts are is so hard with bikes. There are way too many options and don't even get me started on metric v English units.
    Mar 2016
    Yep, way too many standard with no real benefit
  1. I need tips, will this parts replace my bikes original parts
    By leosbike in forum Beginner's Corner
    Last Post: 11-18-2016, 04:03 PM
  2. Replies: 1
    Last Post: 12-05-2015, 06:31 PM
  3. Replies: 1
    Last Post: 02-12-2011, 12:17 PM
  4. Replies: 0
    Last Post: 02-12-2011, 11:52 AM
  5. Some questions about buying parts - but not a "help me pick parts" thread
    By one incredible donkey in forum Downhill - Freeride
    Last Post: 06-02-2008, 03:42 AM
Members who have read this thread: 20
