Results 1 to 16 of 16
    Sep 2018
    minimum travel for bike park
    I was pretty excited to go to a local gravity bike park with my new bike until I read their website more closely. They say that riders need at least 140mm travel to kind of enjoy the park and 200 mm to properly enjoy the park. Well my bike only has 130mm, but I'm a light rider (120 lbs). I would only be hitting small stuff like 5-6 foot tables and 4 foot drops. Do any of you have much experience using a 130 mm bike for dh only runs?
    Reputation: jeremy3220's Avatar
    Jul 2017
    It depends on the bike park and what you're going to ride there. You don't need any suspension for table tops and 4ft drops (assuming your bike can take it). If it's legit steep and gnarly terrain what you're going to discover is that 4ft drops and table tops are not the main issue, the real feature is the setting (the steepness and speed). At bike park speeds your suspension may not be able to keep up. I had a buddy break his trail/XC handlebars while riding (not crashing) a rock garden; just the bump force was high enough to snap the bars. There's a reason people ride DH bikes.
    That said, you might be fine. You can always go, start out on the easiest trail and work your way up. You might could also rent a DH bike.
    Sep 2018
    Thank you. I just bought this bike which was expensive for me with the intention of being able to go to the bike park with it maybe once a month. I didn't even think about travel beyond the minimum I wanted. I guess I could check it out and rent one if mine can't handle it.
    Reputation: fredcook's Avatar
    A lot can depend on how you ride. Those that like to stay planted on the bike, as in seated and arms locked tight on the bars, need more suspension. Not just for themselves, but for the bike. How much the bike needs to be able to handle includes how much body weight is "stuck" to it. If you're up off the seat, arms and legs flexed and limber, your body movement adds a lot of "suspension", and takes weight of the bike. I've seen the heads of riders on 150+mm bike bounce abound as though there were on a rigid bike, as well as seen riders on hard tails whose heads looked like they were floating on a gimbal. But like leremy3220 says, gnarly stuff can be brutal on some parts, like the bars. For that, suspension setup also comes into play. 150mm travel that's nearly locked out can be worse than 130 that's plush. And then there's suspension design. There are 150mm bikes that feel and handle like 130mm, and there are 130's that feel and handle like 150's.
    You didn't quit riding because you're old, you're old because you quit riding.
    jcd's best friend
    Reputation: Battery's Avatar
    May 2016
    Which bike park are you talking about? I'm curious now!
    Trek Emonda | Transition Sentinel | Transition Scout
    Aug 2018
    Give it a shot on your bike. As mentioned, start on the easier trails and work your way up. If it feels sketchy, lock your bike up and rent a DH bike. I'm pretty sure every bike park I've seen has enough green/blue trails to keep you busy at least for a day.
    Reputation: RS VR6's Avatar
    Unless your blasting down at mach speed and blasting every jump...I think you'll be ok.
    Sep 2018
    Bailey mountain in North Carolina. Never been there and it's a 4 hour drive.
    Sep 2018
    I guess the website for it (Bailey Mountain) is putting me off. Minimum travel expectations plus they say they have only intermediate to advanced trails. I know those labels are very subjective though. I'l just give it a shot.
    Sep 2018
    Now I'm just curious; if money were nothing could the shocks just be upgraded?
    I watched a BKXC video on that park. For the trails that he showed...i think the 130 will be just fine. I used my 140mm bike at a couple California bike parks...and I've never felt like I needed "more" travel...but then I'm not sending any jumps and taking the Pro lines. I mainly take the blue and a few black diamond runs. Again...a lot will also depend on how fast you're going. If you go relatively slow...then you might not need that much travel. Also the slacker your bike...the higher the margin of error.
    Sep 2018
    Thank you so much for the advice-i will take it.
    Aug 2016
    Quote Originally Posted by TTOKER View Post
    I ride a V2 SC 5010 130 all around. I've been to Bailey and 130 is not enough. I'm a very active rider and get a lot out of the bike, hit Pisgah and Beech Mountain DH park no problem. Bailey, on the other hand is very steep and very fast. At first it was ok, a bit under-gunned but ok. As the day went on my suspension began to fade and my breaks all but quit.
    It's not the 130 bike, it's Bailey and it needs a long travel/DH bike.
    Sep 2018
    Thank you-! I suspected as much.
    I'm with stupid
    Reputation: hitechredneck's Avatar
    I have ridden every trail at keystone colorado on a 130 bike before. That is a rough mountain. I think you will be just fine to take your bike and go see what it can do and what you can do. Do not let people tell you how much suspension travel you need, go find out for yourself. Like you said you only weight 120lbs which is much different then 160 and way different that 200 and so on. So who are they saying needs 140? the 175lb DH guy? I have seen people rip moab on rigid bikes and some people swear you need 6" of travel. Go find out what YOU need, its is a adventure, go do it!
    Disclaimer: I am a believer that 80% of riders ride with way too much suspension travel then they need for their trails or riding style.
    Jul 2017
    Haven't ridden Bailey but people say it's similar to Windrock in steepness. If that's the case a 130mm bike is probably going to feel pretty sketchy. Like I said it's not so much the rocks and drops as it is the context. Maybe go to places like Pisgah or Beech Mtn. first and work your way up. There's a few (very few) people who ride Windrock on hardtails... but if you have to ask if Windrock is rideable on a hardtail then no.
  1. minimum size of rental car to fit bike with front wheel removed?
    By moshemark in forum Cars and Bike Racks
    Last Post: 10-02-2012, 07:28 AM
  2. Minimum suspension travel for DH bike?
    By purpletrike in forum Downhill - Freeride
    Last Post: 03-14-2012, 06:33 PM
  3. Replies: 6
    Last Post: 12-09-2011, 08:28 PM
  4. Replies: 1
    Last Post: 06-17-2008, 08:15 AM
  5. What is the minimum travel for fork to recommend
    By dblackfly in forum Shocks and Suspension
    Last Post: 06-02-2006, 10:27 AM
Members who have read this thread: 107
