List of 27.5 Compatible 26ers - Page 8- Mtbr.com
Page 8 of 8 FirstFirst ... 45678
Results 1,401 to 1,434 of 1434
  1. #1401
    NedwannaB
    Reputation: JMac47's Avatar
    Nice. What derailleur is that and did you need to use a Road Link adapter to help with the 40t cassette?
    Ripley V1 XC/Gravel Adventure rig
    NINER Rip9 RDO(future...)
    Salsa Timberjack
  2. #1402
    Reputation: Mtbric's Avatar
    XTR 952 drivetrain
    The rear derailleur is an XTR M952. I'm waiting on a extra long B screw. It needs a tiny bit more clearance as-is. I'm using a Dura Ace 109mm bottom bracket for a better chain line. Works great.
    Attached Thumbnails Attached Thumbnails List of 27.5 Compatible 26ers-dsc_2423.jpg
  3. #1403
    NedwannaB
    Very nice build. I have a 952 im going to use also. The Sunrace cassette I'm going to use is on a '17 bike that I'm getting back soon. It worked great with the new style Deore 9spd derailleur with only a slight b screw adjustment. The WT Road Link is suppose to help the older style derailleurs.
    Salsa Timberjack
  4. #1404
    2000 Homegrown Factory 650b finished
    Done. Drivetrain 1x9, 11-40t runs great with the Roadlink. The XTR M9000 levers installed on M9000 front and M960 rear calipers. Had to go flat bars because of the added height. Happy the 2.35 Ardent Race fit pretty well.
    Here's the spec:
    Fox F100 RLC Fork
    Mavic Crossmax SL 27.5 Wheels
    Thomson Carbon Handlebar
    Thomson X4 Stem
    XTR M952 Crankset with XT spider and Blackspire 30t Chainring
    XTR M9000\M960 brakes
    Sunrace 9 speed 11-40 cassette black
    KMC SL 10 Speed Chain
    XTR M952 rear derailleur w Wolf Roadlink
    Easton CT2 seatpost
    Selle Italia Flite Gel Saddle
    Maxxis Ardent Race 27x2.35 Front Tire
    Maxxis Ikon 27x2.2 Rear Tire
    Shimano XTR M9000 Pedals
    Weight 22.4 lbs with Pedals
    Attached Thumbnails Attached Thumbnails List of 27.5 Compatible 26ers-dsc_2577.jpg
  5. #1405
    NedwannaB
    Quote Originally Posted by Mtbric View Post
    Here's the spec:
    Fox F100 RLC Fork
    Thomson X4 Stem
    Easton CT2 seatpost
    Super nice build!👍
    Salsa Timberjack
  6. #1406
    Aug 2017
    Has anyone tried a 2011 Fezzari Cascade Peak?
    Sent from my SM-G935T using Tapatalk
  7. #1407
    NedwannaB
    Red Dragon
    It may be burried somewheres within but just picked up a mid 2000('05 ish)853 steel Jamis Dragon frame that fits my 650 wheel-set. Looks to be the identical frame as the Salsa Bizango I had the setup on years ago. Just have to decide wether gears or singlespeed now. Decisions decisions....
    Build pix to follow.
    Attached Thumbnails Attached Thumbnails List of 27.5 Compatible 26ers-img_4436.jpg
    Salsa Timberjack
  8. #1408
    Sep 2017
    Haro Extreme X7 (2007) with 27'5+ wheels size
    frame: Haro Extreme X7
    fork: Marzocchi RC3 Evo V2 (2014)
    rear shock: CCDB with titanium spring
    handlebar: Reverse Triple X 820mm
    steam: NS Quantum Big
    grips: Chromag Basic
    headset: Sixpack Racing
    tires: Maxxis DHF 2.8 (27'5)
    rims: NS Bikes Enigma Dynamal Roll (27'5)
    shifters: SRAM X0
    rear derailleur: SRAM X0
    brakes: Hayes Trail
    disc brake rotors: Uberbike Components (203mm)
    disc brake adapters: Uberbike Components
    chainguide: Reverse X1B
    cranks: E13 LG1R
    bottom bracket: HOPE
    chainrings: E13 (34t)
    pedals: Reverse Escape
    spokes: Dartmoor Petrol
    front hub: Dartmoor Revolt Pro Petrol
    rear hub: Dartmoor Revolt Petrol
    saddle: San Marco TIME
    seatpost: Reverse Comp Lite
    seatpost clamp: Reverse Long
    Attached Thumbnails Attached Thumbnails List of 27.5 Compatible 26ers-haro-275.jpg
  9. #1409
    4AM
    4AM is offline
    Jun 2017
    80s stumpjumpers work. I have mine set up as a 275x48mm and it's pretty dialed. Got Paul motolites and they have plenty of adjustability since this bike uses rim brakes.
  10. #1410
    Dec 2013
    Can a Fuji Nevada 1.9 26er be converted to 27.5 inch?
    I recorded a video of my bike and if you forward to 0:33 you can see the distance between the tire and the back fork
    https://youtu.be/bQH_qwMg1cQ?t=33
    ^ Let me know what you guys think. Say a 27.5 wheel and a thinner tire which will automatically be shorter giving it much more room to fit? the tires on this bike is 26x2.1
    Would a 27.5 wheel fit with a 27.5 x 1.5" tire???
    The reason I didn't want to put a 26 x 1.5 tire is it would look really stupid the wheel would just look way too small.
    I had an idea of running a massive 26" x 2.5" hookwork maxxis tire though.
  11. #1411
    26" 1x1 Surly Fork compatibility
    I have been running 27.5" x 2.35" Kenda Nevegals in my 26" Surly 1x1 frame and fork for years now with great success. I recently decided to kick it up a notch to a 27.5 x 2.8 Minion DHF plus tires to get a little more cush.
    The 2.8 fits comfortably with a lot of space in the fork. I think a 27.5x3 would fit in this fork. Pretty good for a 26" fork List of 27.5 Compatible 26ers-img_20180622_094313.jpg
    I have a second one for the rear, but I think it will be a little tight. My Nevegal has slightly less than 1/2 in above the tire in the rear, and the 2.8 tire is about 7/16in taller (overall) than the Nevegal (28 3/16 vs 27.75). So my clearance would be ~1/4 inch or less, which is a little close for comfort. I live in a very dry area, so I may try it anyway (no mud build up to worry about), but will try the half plus configuration for starters.
    Stache 7 --- Rigid Surly 1x1 B+ --- Dirt Drop CrossCheck
  12. #1412
    Oct 2010
    Tried a search of the thread but came up blank...anyone run 27.5 on a Soma Analog?
    Plenty of room up front in the Surly rigid fork. End use would be bikepacking and ripping around trails. Too many good parts and I like the ride, but after having a 29er, the 26 wheelsize has lost its luster for me.
  13. #1413
    Reputation: Edward53's Avatar
    Jun 2018
    I see that you have a perfect bike, but in your information about bike I can't see the prise information.How much does your bike cost?
    Bike my life
  14. #1414
    Jun 2018
    sorry, I made a mistake, I wanted to say * price information
    Bike my life
  15. #1415
    Dec 2018
    Hi.
    For the Pinarello FV5 mountain bike:
    Wondering how a small frame would handle a 650b?
  16. #1416
    Nov 2008
    2006-2008 Specialized FSRXC or XC FSR or whatever they are called do NOT fit a 27.5 in the rear. I tried and a tire with any kind of knob will prevent it from having any clearance.
  17. #1417
    Jan 2019
    Info on that particular conversion?
  18. #1418
    Nov 2008
    Quote Originally Posted by MiltonHavoc View Post
    Me?
    Then no. It doesn't work.
    Sent from my SM-G950U using Tapatalk
  19. #1419
    Jan 2019
    Naw, i wanted the info on the rfx way towards the bottom.
  20. #1420
    Apr 2019
    Trek 4400 2008 successfully converted 26 to 27.5 wheel size
    https://www.youtube.com/edit?ar=2&o=...id=rzpsy7SIhdU
  21. #1421
    Armature speller
    Sep 2004
    2011 M5 Stumpy hardtail.
    2.1" 650's fit nicely.List of 27.5 Compatible 26ers-20131214-162221-149.jpgList of 27.5 Compatible 26ers-img_20190328_185437.jpg
  22. #1422
    Hello, i have an GT Avalanche, the frame is an L size, will 27. 5" whells fit my bike?
    Thank you very much.
  23. #1423
    Reputation: dbhammercycle's Avatar
    Quote Originally Posted by Duarte View Post
    Doesn't really matter what the frame size is, unless you have something small so toe overlap is a concern.
    The issue is the clearance in the rear triangle to fit the larger diameter wheel. I'm assuming this is an older 26er, does the frame and fork have disc tabs? If you are using rim brakes, you'll need something that has enough adjustment to reach the rim. Paul's Motolites will work, but are spendy on top of a new set of rims/wheelset. Chances are that you could fit a 2.0 with a larger casing like the Quasimoto tire, or 2.1 with some knobs. If you can fit a larger 26 tire in the back, that may be a better option.
    I don't know why,... it's just MUSS easier to pedal than the other ones.
  24. #1424
    Quote Originally Posted by dbhammercycle View Post
    It's the 2009 model, disc brake. I have an Pro carbon rigid fork , so lots of space in the front.
    Enviado do meu SM-J610FN através do Tapatalk
  25. #1425
    My guess is that a 27.5/650b 2.0 wheel and tire will fit, though I don't know for sure and I don't think you could fit bigger. Can you take the bike to a local bike shop and inquire? The other option is to measure the clearance of the seat stays and chain stays 3/4" closer to the seatpost than your current tire.
  26. #1426
    This is the space i have...the tire is an Michellin xc dry 2.1. Sorry for the bad pictures...
  27. #1427
    May 2015
    2007 Specialized Hardrock
    Nothing factory except the seatpost, awesome bike. Wheels from another specialized 650b bike. Salsa fork, WTB Trail Boss tires, SRAM NX 1X11 groupset, Shimano MT201 hydraulic brakes, assorted random bars, stem, seat, pedals.
  28. #1428
    Apr 2019
    Add trek 4400 to main list convertable models, thanks.
  29. #1429
    I haven't had time to read the whole thread but I converted my Cannondale Prophet to 27.5 and I fut a Maxxis Aggressor 2.3. I think I might be able to go a little wider. Also the Cannondale Gemini can be converted too.
    I'd post a pic of my Prophet but I'm on mobile and I don't know how to reduce the file size. Maybe I'll do it from home later.
  30. #1430
    Feb 2014
    LMFAO That's awesome!
  31. #1431
    Jan 2020
    If I need help/ some inputs on converting my 1994 Alpinestars D735 from 26 to 650b should I post a thread in the 650b forum side of things?
  32. #1432
    Has anyone converted or saw conversions of THIS style Spark 26" frame? Could it be done?
    I know on the first page it says Spark 30 could be converted, but its totally different frame and rear suspension design.
    Its an "medium" size frame. Would like to run atleast 2.2 tires if possible.
  33. #1433
    Jul 2020
    1999 Schwinn S-40 (identical geometry to the Homegrown Factory Suspensions) fits 27.5 x 2.2 Maxxis Ikons just barely, and shown here with 27.5 x 47mm Teravail Rutlands:
  34. #1434
    Aug 2020
    Thank you for your sharing
    It's a good bike , But I like EMTB mostly
  1. List of disc compatible kids frames (<=24" wheel)
    By ridemtn in forum Families and Riding with Kids
    Last Post: 06-01-2014, 11:42 PM
  2. List of Tubeless Compatible MONSTERCROSS Tires
    By FishMan473 in forum Wheels and Tires
    Last Post: 04-23-2012, 03:01 PM
  3. A list of 29er compatible 27,5ers- forks, frames
    By Davidcopperfield in forum 29er Bikes
    Last Post: 03-30-2012, 09:54 AM
  4. My list of 650b Compatible 29ers
    By Thustlewhumber in forum 29er Bikes
    Last Post: 03-30-2012, 12:32 AM
  5. List of belt compatible frames
    By fokof in forum Internal Gear Hubs
    Last Post: 10-18-2011, 07:34 AM
Members who have read this thread: 168
