Results 1 to 16 of 16
    Kenda 2.35 isn't that big...
    Well compared to a 26" 2.35" version. I measure a tires volume by spreading the carcass flat and measuring bead to bead. The 650b 2.35" Kenda measues 5.25" the same as a 26" 2.1 Kenda SB8. I remember a Kenda 650b thread where someone stated the same thing. I was hoping for monster volume like my 26ers but i'll give it a spin , oh well.
    Reputation: GrampBredo's Avatar
    What width rim is it on? Wider rims make wider tires.
    And Kenda's sizing is inconsistent. An old set of 2.35" DH tires I had measured 1.9" in actuality.
    Quote Originally Posted by GrampBredo
    My volume measrment is w/ the tire off the bike ..
    Kenda's sizing maybe.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by keen
    Not the case in the Neves I have measured. In fact the 2.35 "B" is slightly bigger than the 26x2.35. Are you sure you did not get the 2.10 version?
    mtbtires.com
    Quote Originally Posted by shiggy
    Well the tire is marked as a 2.35. I have not mounted the tire to measure the tread width but the Volume is on par w/ a 2.1. I measured my Kenda BG 2.5 and the carcass bead to bead is almost 6" - I recall a 2.35" is between 5.5-5.75" but I don't have one laying around.
    Dec 1998
    A quick check of bead to bead width (inside, not over the tread):
    Neve Bx2.10: 137mm
    Neve Bx2.35: 145
    Neve 29x2.20: 144
    Kenda El Moco 26x2.10: 139
    Tough to measure consistently as the bead edges are uneven.
    mtbtires.com
    Measuring this way is not a accurate way to measure tire width. Your measuring the width of the tread and how tall the sidewall is. Unless the 2 tires your comparing use the same sidewall they can't be compared.
    Mounting the same tire on a wider or skinner rim does not change the width of the tire, only the tires profile. A wider rim will flatten the profile of the tire giving it the appearance of being wider.
    Now if you just want to know the volume of a tire, measuring bead to bead is a great idea.
    Quote Originally Posted by kmorast
    I haven't measured the width of any tires, but if I was going to, I would measure from the outside edges of the tread across the tire.
    I am confused How is measuring from bead to bead w/ the carcass pressed flat different than across the tread from edge to edge - its the same ???
    Neve Bx2.10: 137mm
    Neve Bx2.35: 145
    Neve 29x2.20: 144
    Look pretty close to me. I'd like to see a 26 x 2.35 measured.
    www.derbyrims.com
    Reputation: derby's Avatar
    Just as well. Any bigger and it probably wouldn't clear any 26 inch forks with a safe gap.
    Keen, or Shiggy, do you have a Pacenti 650b tire (any size) to compare with the Nevegal 2.35 bead to bead? (BTW, all sizes of the Pacenti tires from 2.0 to 2.3 use the same casing and should have the same bead to bead.)
    Quote Originally Posted by derby
    Ok interior of tire (outside tread messes w/ the measurment) : Kenda 650b 2.35" measures 5.5" bead to bead, Pacenti Neomoto 650b 2.35" measures 5.5" and a 26 x 2.1 Kenda SB8 measures 5.4". I assumed the 2.35 650b would have the same volume as a 26er, guess not. Again just a volume check tread widths may be as stated. It would be nice if tire manufactures listed bead to bead widths for volume. I have purchased supposed large tires only to find small tire volumes. Go-ride use to list DH tire volume measrments.
    Dec 1998
    Just realized I had a El Moco 26x2.35: 140mm, though it has yet to be mounted and "stretched." It is common for a new tire to gain 1-3mm in (mounted) casing width after being mounted and inflated to max psi for 24 hours. My other numbers are for "stretched" tires.
    mtbtires.com
    Dec 1998
    You have no clue about what you are talking about. You admit to have never measured a tire. I have measured more than 500 tires, all in the same manner and on a control rim. Plus I have measured various tires on different width rims. It can make a significant difference in MEASURABLE size and well as shape of the tire. The results are available on my Tire Site.
    In short, your statement is completely wrong.
    mtbtires.com
    Dec 1998
    The Pacenti tires are 145mm bead to bead
    mtbtires.com
    www.derbyrims.com
    Thanks Keen and Shiggy.
    The prototype Nevegal 650b displayed last year was visibly and by touch much larger volume in casing size than the Neomoto. The prototype Negeval would not have cleared very many 26" frames or forks.
